my 4l80/yank/supercooler/m6 conversion
I need information on how you wired up your neutral safety switch and reverse. I have the same shifter but I have a custom harness to be able to use the ECU to control the transmission rather than having a standalone running it
you should ask your standalone harness people, i dont know what they have included in their harness or not. i took the KISS approach
that part of mine was run by the stock body harness. i ran the two wires that used to go to the clutch over to the shifter p/n switch
the other switch (reverse lights) i ran the two wires that used to go to the m6 reverse switch on the trans to the shifter r switch
