Easiest way to change the transmission fluid?
OK guys-
I am leaking fluid, looks like the gasket got jacked some how..
Either myself or the wife took the car over a hump and dented the fluid pan.. Anyway, I know where the leak is and am going to see about pulling the pan, replacing it and the gasket..
I'm wondering if there is a "best way" to remove the fluid, other than just dropping the pan? If dropping the pan is it, so be it, but I didn't wanna get covered in tranny fluid if I didn't have to..
Thanks
Jeff
Thanks
Jeff
The only other opening I know of is the fill/stick tube. You could suck some out of there, but Id put money on you still having a mess. I just overfilled my trans, and resorted to doing that with a plastic tube. It took a while to get the half quart out that I needed out, but it worked.
Originally Posted by Tram
Sweet.. Thanks..
All this transmission going out stuff makes me want to swap in an M6 for the A4..
Originally Posted by RICEETER
since your pan is dented, i'd just buy a deep pan for a 4L65E from GM.... and they have plugs in the bottom
Originally Posted by waterbug1999
If you think changin out an A4 to get a new A4 back in is hard.. Try changing it to an M6... Just stick with the A4. Sounds like you got enough on your plate right now.
For that price and the work, you would probably be better off considering selling your car and buying another with the opposite transmission already equipped.
