Shift Kit?????????
Probably couldn't hurt... there are plenty of shop reps on here that will probably be able to help. Might be dependant upon milage as to if it's going to hurt anything. I know I love mine.
thanks guys, thats what i wanted to hear. the car only has about 41,000 miles btw. i just want to put the least amount of stress on the rear end as possible. didnt know if the harder shifts would hurt it.
it wont hurt the tranny. it'll actually prolong the life of it. although i would recommend getting the servo's upgraded along with an aluminum accumulator kit, and spacer plate. Contact FLP for more info they are the true guru's.
straight from performabuilt, this is for a TransGo stage 2 kit
Originally Posted by performabuilt
Leave the accumulators stock , But use the largest feed hole sizes, Use no spacers/ Turn the screw in the center of PCS just behind the plug 1/4 turn clockwise. Do everything else according to instructions, This will give you nice part throttle shifts and great performance WOT shifts
Originally Posted by waldershrek
will putting a stall on a stock tranny burn it up?
