yank pt 4400 to ss3600?
opinions?
this is my daily driver. i have a g5x2 cam. I don't track the car any more. I think thats all that needs to be said.
i just want some low end power back and better then 10mpg around town.
What do you expect to lose when you're dropping that far down away from your peak hp? That's the trade off of the smaller, more drivable converter. I'd still swap. You just said you don't track it, so why should half a second matter?
Originally Posted by partyhardoo69
yeah i just talked to yank and the guy said i would slow down .5-.8 TENTHS. not worth it IMO
I would think going from stock to a 4400 would be 5/10 to a 8/10 drop. I would guess it would be more along the lines of 2/10 to 3/10 from a 3600 to a 4400. The biggest gain of an aftermarket converter comes from bypassing those low power RPM. At 3600 you're pretty much entering the power range. I have 2 camaros. One with a 4200 and one with a stock stall. I daily drive the stock one now and really would not put anything higher then a 3600 in a daily. I did daily the other one for 2 years though along with 4.10s so it's not horrible.
Old Drag Racer
Wanna swap for a PT4000? The 4000 might be a tad more streetable and my high RPM horsepower curve would really like the 4400 converter better. Just a thought. Thanks.
On the converter swap you're proposing I can add that I went from 8.20's with a PY3400 to 7.80's once I switched to the PT4000 when my car was bolt-on's only. Not ever headers yet. The shift extensions on those lower stalled converters simply let the engine fall too much out of the powerband for acceptable track performance.
A loss of .2 is realistic; .3 if you have a real top end cam and 4.10s.
