03 truck 4L60E and a 2000 WS6 ?
My torque arm is aftermarket and not mounted to the tail shaft any more, and why do in need a new bell housing ? The trans, it was mounted to a 5.3L witch is the same LS style engine .I have the original torque converter and flywheel, Right now i have the 05 LS2 truck 6.0L block (now 6.8L) in my car right now with the stock 00 WS6 M6 bell housing bolted up to it,with no modification at all.
LS1Tech Sponsor
I was just stating that because I did not know if you had the bellhousing but sounds like your pretty much set for the swap .
__________________
