cant find write up
cant find write up
can sombody please give me a link to a good write up on how to install my Stall converter?
ive tried the search and cant find any...ive tried installuniversity..nothing, and ls1how to...also nothing..
your help is much appreciated.. thanks!
1.Get off you but! And disconnect battery.
2. Unbolt the driveshaft
3. Disconnect the shifter linkage
4. Unbolt the crossmember
5. Disconnect transmission lines (Little clip holds them in)
6. Unbolt the starter
7. Unbolt the flywheel bolt (Remove the plastic insert for the starter) Also have to turn engine to get to all three bolts.
8. Disconnect all electrical harness
9. Undo TQ arm
10. Remove bell housing bolts
11. Break tranny loose. I usally use a pry bar to get the dowels to move.
Thats good enuff Get to work.
9. Undo TQ arm
try both, good luck, Johnny
http://modernmusclecars.net/articles...all/index.html
http://www.zmydust.com/converter.html
Originally Posted by JMBLOWNWS6
The dam site shutdown before I could edit it I have the tranny plugs so no reason to drain any fuild
Originally Posted by stangkiller2005
LOL...dam it..well that helps! im on my way back to the dirty dirty NB! lol
Ill tell you what. Are you coming back allready? Im so confused on where you live now. I can help you get it in. But you going to do all of the work and I am going to coach you.
LOL...dam it..that sounds like a hell of a deal! but naw bro i just started working over here..ima go back..just not yet... ill defenatly keep ya posted!
