Help Tranny swap T56 to auto
The tranny is coming out of a 2000 formula. What do I need to do the swap?? any special mounting brackets? Computer? Not sure what to do.
Also any recommendations on transmission builders? Thanks for your help.
Originally Posted by 408z28
Do you need a trans or do you allready have one? I have a couple of extras laying around(4l60e & th400) I trade with ya.
Transmission cooler lines
Radiator for auto or an external trans cooler
Flex plate , Torque converter
trans cross member
auto shifter with cable
pcm and wiring for auto to function properly
brake pedal assembly
modifications for neutral start switch
Auto console top section
This is the best I can give you, my M6 to auto swap was to a TH400
there may be a search for your situation
trans cross member
