Quick ?, 4L80E bellhousing shield bolt pattern
Old 09-16-2007, 10:27 PM
5150mechanic's Avatar
Default Quick ?, 4L80E bellhousing shield bolt pattern
,,,,, will a dust shield from a newer 4l80e from a genIII engine bolt up and line up correctly to say a 97 4l80e? I like the thought of the shield bolting in to the oil pan. Thanks in advance, Mechanic.
Old 09-17-2007, 12:28 AM
8a8mfh's Avatar
Yes it will, I've done it with a '98 4L80E and '04 dust cover.
Old 09-17-2007, 12:33 AM
Sweeeet, just checkin,,,, has the same (4) 10 or 11 mm. bolts to hold it on,right.
Old 09-17-2007, 12:41 PM
8a8mfh's Avatar
Yep, I thought it was overkill to hold the thin steel dust cover on with those huge bolts until I swapped one in behind an LS1 and used the aluminum cover.
The bolts are slightly longer with the aluminum cover.
Quick Reply: Quick ?, 4L80E bellhousing shield bolt pattern
