Hows it look? Yes? No?
just moves when i push it. no button, which is a bit of a problem that i havent taken the time to fix yet, because when i put it into park, i have to pop it off. for some reason when you put it into park the button is about an eighth of an inch higher than any other gear. but, for now its nice...kind of like an anti theft shifter lol
i really like the shifter ****, all it needs now is a shifter boot and I would consider it the best looking automatic shifter set up. nice job
it looks like you cut the shifter stick down and did you have to use an adapter to use that ****?
no, i did chop the shifter but there was no need for an adapter, i did however need to use an outside threadding die to be able to screw it on (its a screw on). alot easier than you would think.
