4l60e dipstick tube help
Old 11-08-2007, 05:03 PM
FSANE's Avatar
Default 4l60e dipstick tube help
I was doing heads and cam on my friends 98 ta and forgot to put the dipstick tube back before the heads were bolted on. After trying to install it back I bent the tube badly. We just ordered a new oem replacement, but now the heads and the intake are back in the motor.
What's the best way to install the dipstick tube back with out damaging it.
Thanks
Old 11-08-2007, 08:32 PM
GregWS6&z28's Avatar
you should have bought a flexible dipstick
Old 11-08-2007, 10:02 PM
FSANE's Avatar
i should of pulled the whole engine out and did head and cam that way. Should of... Would of. Your answer is not helpfull.
Its his car not mine.
Old 11-08-2007, 10:16 PM
Hugger's Avatar
Been in your same situation. If you take your time and snake it back in there carefully it will go. It is a finesse thing. I have the bent dipstick to prove it. It is one of those things where you have to hold your mouth just right to wiggle it in. Kind of like a puzzle. Hope this helps. It can be done!!!
nevermind
Old 11-08-2007, 10:23 PM
FSANE's Avatar
"we ordered"
we should have done some research.
goodluck
Your answers are a waste For this Forums Banwith. Unless you have a helpful answer to the current situation, keep the "Should Of" thought to yourself.
Old 11-08-2007, 10:24 PM
FSANE's Avatar
Thanks Hugger.
I am going to try it right now. I hope I still have some energy left because I just came home from Work.
Old 11-09-2007, 12:34 PM
FSANE's Avatar
nope. Still no luck
Old 11-10-2007, 04:34 PM
Got Me SOM's Avatar
i have a stock one in my garage if that one is too bent out of whack.
Old 11-10-2007, 06:34 PM
454mag's Avatar
If you lower the tranny a littlle by dropping the crossmember while supporting it with a jack it should give you enough room. Makes it easier to get that 15mm bolt that holds the dipstick on also.
Quick Reply: 4l60e dipstick tube help
