Borg Warner HD clutches
Old 12-21-2007, 06:04 PM
DRIVER456's Avatar
Default Borg Warner HD clutches
Who sells Borg Warner HD 3-4 clutches?.................Paul
Old 12-21-2007, 06:53 PM
Gilbert@Ace Racing's Avatar
I could sell you some if you would like.
Or any transmission supply house.
g
Old 12-21-2007, 07:16 PM
DRIVER456's Avatar
I have the Zpac in now,But I'm having 2-3 shift problems at WOT.If they are burnt I will call you.I will look at it tomorrow after I finish draining the trans.I might just have to tighten up the clearance........Thanks.........Paul
Old 12-21-2007, 08:14 PM
Don't hesitate to give me a call ... I'll be in. Good luck wid it!
g
Old 12-23-2007, 05:16 PM
DRIVER456's Avatar
Well I had over .100 clearance on the 3-4 clutches,Alittle to much.I guess thats why I had 2-3 shift problems.I took it apart and added a thin steel at the bottom and got the clearance to .025 to .030.Hope that works.The ZPac still looked good after 5000mi and some 1/4 mile passes.................Paul
Old 12-23-2007, 06:56 PM
Good Luck with it.
Holler if you need anything.
g
Old 12-24-2007, 12:02 AM
LS1Tech Sponsor
performabuilt's Avatar
Yes that clearance is aprox what we use with the Zpack , And should do fine however I suggest you use the thin plate between the top backing` plate and the special plate, The apply plate is made as it is for a reason with the groove and you dont want to defeat that , Its part of what keeps the set from coning in high heat, We have had excellent results with the Zpack . Good luck
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-24-2007, 05:41 AM
DRIVER456's Avatar
Ok I can still change it,I'm waiting for gaskets.Thanks Frank.............Paul
Old 12-24-2007, 06:37 AM
FLT
FLT's Avatar
Here is a kit that we sell and also install in our units. http://finishlinetrans.com/store/pro...products_id=62
Sounds like by reading your thread that you have a clearance issue. Good luck with it. Vince
Old 12-24-2007, 08:30 AM
DRIVER456's Avatar
Thanks Vince.I have another problem,There is no waved plate in the forward clutch,I must Have thrown the old one out.Do I need it,Or can I get away with out it***UPDATE I FOUND IT*** That sucker was hard to spot................Paul
