Lock-up with 4L60E full manual valve body
i know there's not a whole lot of people out there with a fmvb in a 4l60e but maybe there is someone out there that can shed some light. what is the easiest and best way to keep lock-up when installing a mvb?
fwiw, i will be running the stock shifter for now but soon will be going to a ratchet shifter and wanting to know how to make the reverse lights work
Well, if it was originally equipped with an A4, you will not need to do anything in order to retain Lock-Up.
If it is a conversion, then there are several ways to manage Lock-Up. But I would need to know the powertrain combination in order to spell some of those options out.
As far as the reverse lights, the B&M Pro Ratchet and many other shifters come from the manufacturer with both neutral and reverse lamp micro switches! It's just a matter of identifyiing the wires and swapping terminals... Piece of cake there huh?
g
g
gilbert, its an original a4 car. im just putting a mvb in it and want to retain lock up in OD. the main harness plug is going to have to be left unplugged, so there are no electronics telling the tranny to lock the converter up, right?
either way, isnt there some tuning that must be done to make the lock up work? this is all new to me since the number of ppl who has done this is very scarce.
That's right, when the transmission electrical connector is unplugged the PCM cannot control Lock-Up. Not sure why you are being told to leave the transmission electrical connector unplugged. I have never had to do that using traditional modifications when taking a 4L60E to full manual.
The only Tuning that might need to be done is to turn off the reporting of Shift Solenoid and EPC DTC's. At least that's all I can remember for now. Other than PWM, Lock-Up functionality is not affected by using Trans-Go's HD-3 Reprogramming Kit, therefore no Tuning should be required for the Lock-Up feature to operate. That is the only kit I have used to take one full manual.
Good Luck with it,
g
Good Luck with it,
g
I've done a half/dozen of the HD-3 kits which converts to full forward manual control on the 4L60E. Gilbert your correct, you leave the trans 13 pin connector attached as normal. Frank, the connections they have you unplug are the two shift solenoids which reprogramming will be required to shut off both shift solenoid codes as Gilbert mentioned above. TCC will remain unaffected by this modification as well, just FYI.
thanks for advice guys. i dont want to get any sort of argument war going on here but we may all learn a lil something in the end.
honestly, it really dont make me any difference to plug it in or leave it unplugged. the only thing i care about is retaining my lockup. keep in mind, my tuner is 3 hrs away and i may not be able to take my car to him immediately. i would like my lockup to work before i have time to take it to him if at all possible
thanks
thanks
LS1Tech Sponsor
thanks for advice guys. i dont want to get any sory of argument war going on here but we may all learn a lil something in the end.
thanks
thanks
__________________
