4l60/4l80 Tranny Temp Sensor Locations?
Old 02-26-2008, 08:43 AM
nahasapeemapetalon's Avatar
Default 4l60/4l80 Tranny Temp Sensor Locations?
I am installing a 4l80e and ordering cooling line fittings and want some input.
I think most recommend in the pan?
Where did everyone mount there tranny temp sensors?
Pan? In line with the cooling lines? Can you use an output from your computer?
I will have hp tuners so I can probably read it from there occassionally.
Old 02-26-2008, 09:42 AM
Z'mnypit's Avatar
Mines inline with the cooling lines. Cut the rubber line in half up by the cooler and installed an earls fitting that had a spot in the center to screw the sending unit in. The temps dont read as hot as it would inside the trans but if it starts going way hot up by the cooler I know I have a problem.
Old 02-26-2008, 09:43 AM
99Hawk262's Avatar
I used the feed line to the cooler since I wanted to see the absolute hottest temps my tranny ever saw. The fluid inside the tranny is cooler than the fluid coming out of the converter via the cooler feed line. My gauge averages 100-150 cruising and 150-180 in traffic. Most will recommend the pan for average temps. Either should work just fine.
Old 02-26-2008, 09:50 AM
99Hawk262's Avatar
https://ls1tech.com/forums/automatic-transmission/867992-factory-trans-temp-sensor.html
Here's some good info.....Gilbert at ACE chimed in with some expertise. Basically, use the pan for average temps, use the cooler line for max temps.
Old 02-26-2008, 09:59 AM
Sounds good guys. Thanks. Another couple hundo for a gauge haha, but itll be good to know.
What cooler you guys buy? You think a cheaper flex a lite cooler would work or you guys strictly b&m?
Hawk...you have rubber hoses right at cooler as well?
Old 02-26-2008, 10:23 AM
AutomagicLS1's Avatar
Mines mounted in the pressure port and actually reads hotter than what the pcm says.
Old 02-26-2008, 11:07 AM
Whatd you guys use for gauges, imlooking at an autometer electrical gauge that has a sender without threading...I was hoping to have a temp sender with threads so i could put it in line with my braided hose...
Any suggestions?
Old 02-26-2008, 11:21 AM
Z'mnypit's Avatar
Im using the autometer phantom 2 1/16th elcrtical trans temp. Mine came with a threaded sending unit. Got a local speed shop you could go to and look at them?
Old 02-26-2008, 12:31 PM
z-ya's Avatar
I'm useing a vdo temp and line pressure gauge on mine both senders are 1/8 npt.
Old 02-26-2008, 03:29 PM
RamAir02TA77's Avatar
Im using the autometer gauge I just threaded the sender into the pressure port it reads within 5 degrees of the pcm not sure if it reads higher or lower anyway it works good enough for me.
Old 02-26-2008, 03:45 PM
99Hawk262's Avatar
Yes, I run rubber Goodyear hose and fuel injector style clamps. Just to throw it out there, we've seen as much as 27* difference between what the PCM read and what my gauge read. The PCM read cooler.
Old 02-26-2008, 05:14 PM
How do we know which one is more accurate?
Old 02-26-2008, 08:00 PM
99Hawk262's Avatar
It's been stated many times that the pressure port location is not accurate. That's what I've always read and is the reason I did not use that location. The pan would be more accurate for average temps and the cooler line for max temps IMO.
Old 02-27-2008, 07:49 AM
My autometer nitrous gauge came with the 1/8 inch sender and a blue npt npt fitting for the nos to flow through and the 1/8 to T into that.
Do the temps come with that blue fitting as well so you can mount it in line at the cooler location?
http://www.autometer.com/cat_accesso...il.aspx?vid=37
http://www.autometer.com/cat_accesso...il.aspx?vid=36
Old 02-27-2008, 07:56 AM
http://store.summitracing.com/partde...5&autoview=sku
something along these lines for tranny fluid...does this come with it guys?
sorry for all the questions, just making a summit order
Old 02-27-2008, 09:37 AM
Z'mnypit's Avatar
Kinda, mine is like that but both ends are made for a hose to slide over but the middle is identical. Ill see if I can find one
Old 02-27-2008, 09:48 AM
Z'mnypit's Avatar
This is what I have. My only problem was the sender was a little to long to fit so I called autometer and they sent me a short one. Even on the short one I had to grind it down a tad on the end
Old 02-27-2008, 07:35 PM
Im sure the pressure port and the pcm would get me close enough to let me know if there is a problem or not. Im just sayin how do we know the gauge is 100 percent accurate and the pcm is not. Im not trying to be smart here im just curious?
Quick Reply: 4l60/4l80 Tranny Temp Sensor Locations?
