700r4 on LQ4
Old 03-02-2008, 09:50 PM
supreme84's Avatar
Default 700r4 on LQ4
hi, i'm getting started on my 6.0 l project and somebody told me that if i want to fit my 700r4 on my 6.0 lq4, i would need a flexplate from the combo 6.0l and 4l80. is it true ??? cause i verified and my engine had the 4l60 ( there is 3 holes to bolt on the torque) but i measured from the block ( where it is punched 6.0L ) to the end of the flexplate and it gave me 1 and 1/8 inch. i also verifyed on several other 6.0l (maybe 5 or 6) and 5.3 and 4.8 and my flexplate is the most far from the engine. please could you tell me if i need the spacer because i'm preparing the engine but i don't have the tranny at home !! thanks !
Old 03-04-2008, 04:58 PM
supreme84's Avatar
could someone tell me ?????
Old 03-22-2008, 12:11 AM
DP506malibu's Avatar
Default 700r4
http://cgi.ebay.com/ebaymotors/700R4...spagenameZWD1V
I hope that helps
Old 03-22-2008, 06:15 AM
jay_lt4's Avatar
is your flex plate curved or flat,, you need the flat flexplate and spacer from a 6.0L that came with a 4L80e trans, or just get the hughes spacer
look here for more details:
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
Quick Reply: 700r4 on LQ4
