WOT lockup question
Old 03-30-2008, 04:03 PM
C_Rules's Avatar
Default WOT lockup question
Wahtsup everyone. I've heard a lot of talk about locking converters at WOT. What exactly does this mean? If I'm at the track with my vig3200 doesn't it lock up at some point down the strip? The only reason i ask is because i know locking up a converter with a single clutch converter at WOT can damage it especially on the spray.
Old 03-30-2008, 08:01 PM
Circle-D's Avatar
Good question, WOT - Wide Open Throttle. Just what it sounds like, the clutch in the converter gets applied, typically in 3rd gear, when you are wide open throttle. This is only done if your programmer tells it to. From the factory the PCM tells the converter clutch to turn off when the car is WOT. A low HP car might be able to handle a WOT lock up with a single disk, but would probably eventually burn the clutch up. The single disks are not designed for this, you have to have a lot of extra clutch capacity to handle the WOT lock up.
Chris
Originally Posted by C_Rules
Wahtsup everyone. I've heard a lot of talk about locking converters at WOT. What exactly does this mean? If I'm at the track with my vig3200 doesn't it lock up at some point down the strip? The only reason i ask is because i know locking up a converter at single clutch converter at WOT can damage it especially on the spray.
Old 03-30-2008, 08:02 PM
FLT
FLT's Avatar
I would not recommend locking any single disk converter at WOT. I have heard and seen plenty of them fail from doing so. When people talk about locking up the converter going down the track, they are talking about the torque converter clutch. This usually done with a manual switch wired into the lock up wiring circuit. The idea is make the crankshaft and the input shaft turn one to one without any slippage from the converter. Some will do this once in 3rd gear as doing it before hand, such as in second is very hard on a transmission. Others will just use it to buy a few hundred rpm when getting to the end of the track to keep from running out of rpm and having to shift to 4th. This helps in some cases so that a gear change or a tire height change does not need to be done as well. Hope this helps you understand. Vince
Old 03-30-2008, 08:35 PM
C_Rules's Avatar
Chris
i knew the definition of WOT ...thanks for the rest of the explanation thats what i was curious about. i just wanted to make sure that the pcm was not telling my converter to lock up in third at WOT. i was concerned about that. thanks!
Old 03-30-2008, 09:07 PM
bad2000z's Avatar
Sooo....would a manual lock up switch be a bad idea with my TCI4400??
Old 03-30-2008, 09:15 PM
Self-Admitted Scammer
ls2pontiac's Avatar
what about locking it in 1st at 5500 rpm while the gas is floored? lol.
Old 03-30-2008, 09:26 PM
FLT
FLT's Avatar
The problem is when the trans shifts with the converter locked it is very hard on the internals of the transmission. I would not do it especially in 1st!
Old 03-30-2008, 11:31 PM
00cls1camaross's Avatar
is it actually beneficial if i am running say from a dig to 160 mph... my car shifts at 6000 rpm but at 125ish in 3rd. i used to be in the 135 area with my stock stall. would it help to get the extra gearing out of your car when racing to those speeds? i think it would but i have no evidence to back it up.
Old 03-30-2008, 11:38 PM
LS1Tech Sponsor
performabuilt's Avatar
Locking in 1st very bad idea . The converter does act as a cushion to the shifts. Lock it and thats gone. Similar to hitting each gear with a 20 lb sledge hammer. Lock up during shifts a bad idea IMO
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-31-2008, 09:35 AM
bad2000z's Avatar
My question is, can i lock it up in 3rd to avoid bouncing off the rev limiter going through the traps? Otherwise I'm gonna switch to 28" tires.
Old 04-26-2008, 04:41 PM
C_Rules's Avatar
my tune has my TC set to lock at WOT at 95mph in 3rd gear. is that okay. would i run quicker if i bumped that up?
Old 04-29-2008, 08:18 PM
C_Rules's Avatar
^^anybody? could locking my converter at 95mph @ WOT damage it?
Old 04-29-2008, 08:26 PM
LS1Tech Sponsor
With a single disk converter there are risk of damaging the clutch but additionally if you lock it during a shift there is considerable risk of damage to the input shaft and drum.
Some people do it and all goes well but sometimes
__________________
Call 888-744-6542
