after transgo HD2 shifts way too hard
just thought id comment on shifts are the HD2 kit was installed. First off my tranny guy says that its tired and will need a rebuild soon. He installed 3 washers to compensate for the "tiredness" and left line pressure up. Man im not liking the shifts from 1 to 2. Really hard and not to my liking. Anyways comments are welcome and TIA guys!
Pontiacerator
Start by getting at least two of those washers out of there. Then you can check the accumulator valve while you're in there. And it's always been considered a no-no to have your line pressure jacked up in addition to a shift kit install. If the shifts still seem harsh after doing the first two items, I'd go back to a factory line pressure setting - at least on the 1-2 shift.
I never use any on my builds or in my modified TransGo Shift kits. Having firm to very firm part throttle shifts will shorten the life of the transmission. It does nothing for longevity.
As a note this is in a '03 S10Blazer with a 4.3L V6 and I think part of the problem is I don't have enough power to turn/chirp the wheels on the 1-2 shift (well right now at least, I'm working on an eaton Blower for it) I initially had 1 washer and removed it last weekend and while not as harsh it still is harsh. Another contributing factor is the 285/40ZR18 KDW's I got hanging out back, just too much traction at the moment.
I would appreciate any advice you guys can give.
If the Line Pressure Tables were modified in the Tune, then all of the adjusting of shims will most likely not help a harsh engagement. Those tables need to be set to stock in order for the new mods to do their jobs properly!
If it is tired, he builder is referring to clearances... clutch pack clearances, bushing clearances, pump clearances etc.....
It sounds like it would be best to begin to plan for a well built unit now, rather than trying to scramble for a replacement unit when and if it fails.
Good Luck with it.
g
Good Luck with it.
g
Better to leave all springs, and washers out than to install 3 washers= same thing, less trouble.
There is little difference in 1-2 shift quality between the 1-2- or 3 washers. The biggest change comes with the apply orifice.
Check that the 1-2 accumulator regulator spring isn't cocked in the bore!
In my experience 1, 2 or 3 washers completely owns the 1-2 shift quality. Better to go with no washers on the 1-2 accumulator as the re[lacement spring is already firmer than stock to start with. Any shift quality can be bumped in the tune due to the extra available line pressure after the kit going in.
I've had my out valve body out 3 times after I installed the shift kit and I found that doing exactly as the instructions say for feed hole mods is perfect. On the 2-3 hole I went way too big and my ECU set the car on limp home LOL
No washers would be the go, 3 is too extreme IMHO
