trans temp sender ?
trans temp sender ?
im in the middle of installing a auto meter trans temp gage #4757 i took out the service plug on trans and the sender that came with the gage is 3/8" longer then the service plug it seems to be bottoming out before it's tight
has any one had a problem with this?
It's not hitting the band, if anything it will block the fluid passage. That plug you remove is the pressure test port.
I always tee my sender into the cooler line out, that way you read max fluid temp.
well i got some washers and filed down the end of the sender some so it will be close to the size of the plug i took out so i will see if that works. but what would you do?
Put it in the cooler line for a more accurate reading, thats what I would do.
You put it in the case it reads a lot off the case temp. Put it in the pan and it reads a mix, an average temp.
Ever see one of those charts that tells you what happenes to trans fluid at certain temps?
Put the sender in the line going to the cooler, thats where you can read the highest temp.
Case temp will read consistantly high, pan temp will read consistantly low. Cooler out temp will swing back and fourth 50+ degrees in less than a minute accelerating from a stop to 70 mph starting with the trans at operating temp.
Depends on if you want a gauge to impress your friends with or a gauge that tells you something.
VInce is there anything one could block by installing a temp sender into the pressure port?? I usually just use a "T" and put the sender in the "T" on the pressure port. The LT1 cars have a temp sender you can access from a Datalog, thats on the cooler line.
