changing Shift Solenoids
can someone please tell me how to do it? ima attempt it tomorrow. ive changed the vss, had the gears calibrated, tire and wheel size, and po751 and 757 codes deleted. still have same problem. so i guess this is the next step.
what is the best place to pick these up at? should they have them at any autopart store?
What exactly is going on?
I had a problem where if I left the car in "OD" in traffic, once the car would go into forth and lock and unlock the converter (from slowing down and speeding up) the PCM would freak out and I'd loose first and forth. I replaced both solenoids and it didn't change the problem.
I just started to leave the shifter in "D" around town until I got on the freeway where it wasn't necessary for the converter to unlock and lock from speeding up and slowing down with traffic. I'd suggest that before replacing the solenoids if you haven't already.
Good luck.
Good luck.
Good luck.
Good luck.
im compleatly locked out of 2nd gear. cant manually downshift. can automatically down shift. nothing. it like really annoying.
Be careful when you pull the clip out there are springs behind the solenoids. I pulled the clip holding the soleniod, it shot out and I spent 10 minutes looking for the spring.
thanks for all the help!
