best performing auto gears?
Old 04-28-2008, 07:22 PM
lt1noob's Avatar
Default best performing auto gears?
so i was kinda wondering what the "1, 2, 3" gears did today because i know on trucks they're for towing. so i throw it in 2 and the whole car shifts and im like what the ****, but the throttle got real heavy and the thing was a damned torque beast, same with 3 but even more torque. but my question is, which setting is best and quickest? im guessing 3 but im not sure. also when i tryed a run in 3, i did with "transmission perform" button and without, and didnt see much of a difference. so with "3" should i still put on the button or not? just give me feedback, anything, i want to know what gear/combo of gear and trans perform button is the best and quickest.
Old 04-28-2008, 07:40 PM
lt1noob's Avatar
anyone, i really would like to know this...
Old 04-28-2008, 07:58 PM
b00sted's Avatar
Um, what?
1, 2, or 3 doesn't affect power or torque. It's just each gear, you can manually shift from 1-4 but it's not necessary at all. Leave it in '3' at the track and let it shift itself.
And as far as the car 'shifting' when you put it in '2', you're either lying or you threw it into 2 at 45 mph.
Old 04-28-2008, 08:14 PM
lt1noob's Avatar
well yea but, if i go from "D" to "3" theres alot more torque, so your saying, "3" is the best setting for power right? thats what i needto know, and if i should also use "performance trans" button too or not.
Old 04-28-2008, 08:15 PM
lt1noob's Avatar
i dont know why theres more torque, idk just seems alot more power launching.
Old 04-28-2008, 08:16 PM
lt1noob's Avatar
i didnt think it made a difference so i never tryed but idk...tryed it out today and now im kinda curious.
Old 04-28-2008, 08:24 PM
Fast GTO's Avatar
There is more torque because your RPM's are jumping and putting you higher in the power band.
Go read up on the interweb about gear selection v. RPM v. power
Old 04-29-2008, 07:16 PM
Hark_Z's Avatar
D is 3.
Old 04-30-2008, 11:58 AM
lt1noob's Avatar
ok so what i want to know...example... if a stang pulls up beside me on the street, and wants to be a cocky little ****...what gear should i put it in to kick the **** out of him. and should i use the transmission perform button too or not.
