th400 wiring diagram
I don't get it? I've searched and searched and there is no real description on how to wire up a th400 conversion. Lot's of people have done it, I can't believe I can't find it on here. I've read the frequently asked th400 thread and the wiring section only shows a couple jumpers that I don't even know where they are located. The stock a4 had a bunch of **** hooked up to it and now this hurst shifter has a hook up for the shifter cable and two prongs for a wire hook up in the front. Other than that its just the trans brake plug.
I'm going to post pics so those that have done it can chime in and let us that are trying see exactly what goes where. Hopefully this thread can be very helpful for all the other people that run into this. I found many people looking for answers but no answers lol.
What do we need to do with this stuff?
Heres the stock stuff:
Heres the Hurst shifter:
Please, anyone that can help with this stuff, it would be a big help for me and I'm sure many others that are trying to or planning to do this.
Thanks,
Lou
Thanks,
Lou
Location: Your girl's back door giving her the long stroke while you're at work
I can't see the pics cause photobucket is blocked here at work but I'll try and answer your questions.
The two prongs on the Hurst are for the backup lights and the neutral safety switch. I never hooked up the reverse lights on my Hurst when I went TH350 so I can't tell you which wire you need to splice into. None of your stock connects will plug into the TH400, unless you got the conversion kit for the vehicle speed sensor.
Like I said I didn't hook mine up so I don't have any pics. And I never hooked my speedo up, I went by the RPM to figure my mph
Someone makes the conversion kit for the VSS but I forgot who it is
Sorry
Sorry
Yes, GM makes replacement parts. Say for a 1988 GMC Sierra 2500 with a th400. For that application get a speed sensor and reluctor wheel. The only thing you need to pay attention to is the reluctor wheel inside diameter size. Last I seen in the sticky thread only one was listed but there is two. One with a small ID for long tail 27 spline outputs and one for large ID 32 spline outputs. GM factory parts and the right plug it will all fit right on.
In the sticky thread for A4 to M6 swap is a pic and info of the wiring colors and what they go to. All you need are two for the backup lights and two for the neutral safety. And splice two together for the rear hatch if you use the button.
Yeah, thats the FAQ I was reffering to. A lot of good info but not enough specifics on the shifter and wiring. I was hoping someone could identify all the hook-ups that go on the stock a4 shifter and what to do with them when using an aftermarket shifter. You have some jumpers listed but I can't tell where those wires are located.
Listen I just did this a few months back with a TH350 swap...freaked a little with the wiring (mainly cause I hate electrical work). Take your time and read dlove's write up. That shifter cable I pulled completely out and trashed. There was a few loose wires I just tucked away under the console...no use for them. Follow dlove's wiring write up and to hell with all the rest of it. I do not have reverse lights either...not as big of a deal as I thought it would be. You could hook it up to a manual switch if you want, thats trouble I didnt bother with. I used the pro-ratchet from B&M...looks like it hooks up the same. You will need a complete cable kit for this, or thats what I did.
Wiring
You can wire in your factory shifter wiring to your aftermarket shifter if it comes with options to do so. If not you will need to do the following-
A4 cars, connect these wires together that come out of the old shifter harness. It is a 6 wire connector going into the factory shifter.
purple + dark green = neutral safety switch, must be done to start vehicle
orange w/ black stripe + black wire = hatch release to work.
Finally the brown and light green wires should NOT be wired directly together. Doing so will cause your reverse lights to stay on at all times. You can run them threw a momentary switch or just leave them apart like i did.
Much better, thanks. It's a little confusing that nothing actually goes to the new shifter, just the stock wires getting spliced together lol.
So I got what to do with the stock wires for the shifter, but what goes on the two prongs on the new shifter? Does nothing else matter on the new shifter except the shifter cable and the trans brake? I can just pitch everything else that was hooked up to the stock shifter?
Thanks,
Lou
Thanks,
Lou
i just bought the same shifter from speed inc hopefully it comes soon so i can start my install,this thread will help me out also cause i too am confused with a th400 switch,i hear different things from everybody
you dont have to hook them up though. If you do it like I said, the car will start in any gear and will not have any rev lights. Or you can figure out from the hurst instructions what you need to do to wire it with the shifter if you want those items.
Yeah, I got them hooked up on the switches on the shifter. I don't have pics of it but I think I can get some for you. I'll need to get the center console off to refresh my memory and get pics, I need to get it off anyway for something else so when it's off I'll take some and let you know.
No, unfortunatly I can't take the console out right now bcause the car is jacked up in front and I can't move the shifter out of park. I'm having some issues with getting my engine started so it might be a while.
This is how I wired them up though, instead of connecting the wires together for the neutral safty and reverse lights, you just hook them up to the switches on the shifter. The only thing you need to figure out is which switch is which on the shifter.
purple + dark green = neutral safety switch, must be done to start vehicle(connect to one of the switches)
brown + light green wires = reverse lights (connect to other switch on shifter)
It's easy to figure which switch is which if you have the battery hooked up because if the switches are reversed, the reverse lights will be on in park.
If you wire it up like this your reverse lights, nuetral saftey switch and hatch release will all work just like they did with the 4l60e.
either purple or dark green wire to one of the wires from the shifter.
then either brown or light green to the other wire from the shifter? you dont have to wire say the purple and dark green together ten to the wire on the shifter? did i tell you i hate electrical
thanks
ok so correct me if i wrong
thanks
thanks
