tranny is in neutral wont engage into any gear
i started my car up after getting my starter ear welded back on and made sure all my fluids were good so i went for a test drive arround the firestone parking lot after about 4 or 5 laps arround the store i came to a stop and the car died, i started it back up and went to put it in drive but drive never kicked in, no reverse no forward but if put in park in doesnt move. we lifted it back up everthing is still connected verter is bolted on, the linkage is hooked up and u can c the lever on the side of the tranny moving but nothing. we hooked up the scanner and it shows current gear 1st and does not change regardles of what gear the selector is on. could i have burned it up it was built b4 it went in my car and i have only put about 8k miles of street driving on it. fluid coming out is very clean not sure what step i should take nxt
From what I read you have had it out to repair the bell housing . If that is the case you may have misstabbed the converter in the pump and damaged the pump rotor . I hope that isn't the case , but you can check it by pulling the dipstick out with the engine off and marking the fluid level on it and then start the engine . Check the level again . If the pump is working the level will drop with it running .
the repair was done on the block cuz my starter broke and broke the ear off, but i will chek the fluid this way 2morrow,would fluid be leaking if either of those is broken?
well the trans was removed and the converter aswell and sat for about 5 months. when we were putting it in it didnt want to go in all the way so we took it back off and the verter was not all the way on the shaft but we never forced it. we thought it was electrical but no wires seem to be damaged. i guess ill have to take it off
took the tranny off and found 2 little metal peices behind the pump seal. do i have to get a new pump or what do i have to replace if it is the pump should i go with a 13 vein pump
