4L60E shift problems
Old 09-15-2008, 09:28 AM
paulc87's Avatar
Default 4L60E shift problems
Hey guys, drove my car to school this morning and my car will not do the 1-2 shift without letting off of the gas. It also won't shift into 4th gear or whichever gear it is supposed to be in around 45-55. Other than that the trans runs OK. I haven't had time to check the fluid yet but I was just seeing if anyone had any quick ideas.
Trans is "performance" rebuilt with around 40k miles, I rarely ever drive it hard so I can't see this being glazed bands/clutches or anything
Thanks
Old 09-15-2008, 09:37 AM
LS1Tech Sponsor
performabuilt's Avatar
First do you have any codes or check engine light? The next if if the only issue is with 2nd and 4th i would suspect a 2-4 band issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 09-15-2008, 09:59 AM
paulc87's Avatar
I forgot to mention that I have the infamous "P1870" code. It's been tripping since I bought the car over a year ago.
Old 09-15-2008, 10:03 AM
LS1Tech Sponsor
The 1870 code will cause very high line at all times if this has been ocuring for this long its very possible you have damaged the 2-4 band from the constant excessive line pressure
__________________
Call 888-744-6542
Old 09-15-2008, 03:28 PM
paulc87's Avatar
Can I get that band replaced without having to rebuild the entire transmission?
Old 09-15-2008, 03:44 PM
LS1Tech Sponsor
Depends on the condition and many shops are unwilling to just replace a single part
__________________
Call 888-744-6542
Old 09-16-2008, 02:13 PM
paulc87's Avatar
I got around to checking the fluid, it is good and pink. Does this make any difference?
Old 09-16-2008, 03:53 PM
LS1Tech Sponsor
not really all that tells you is its likely not burning friction material but it col still be broken , Band eye pin torn through partially maybe , You or someone will have to go into it to figure it out
__________________
Call 888-744-6542
Old 09-19-2008, 09:38 PM
paulc87's Avatar
You were right, I got it checked out and it is the 2-4 band. Thanks
