Question for the TH400 guys
I had to pull my tranny tonight..and the top bolt on the drivers side was pita. Do any of you guys just run 4 bolts and not put the top one in? Its such a pain to get to on my car..would it be an unwise decision to not put that bolt in? Thanks.
Its a pain to get to but I didn't think it was that bad at all. I had the trans in and out 3 times and once you catch on with about 2 feet of extensions and a swivel its not bad to get in and out. I think I used 1 12" wobble extension, 2 more different legnths extensions and a swivel with a socket on the end of the swivel. Ratchet ended up next to the trans mount.
i have a bunch of wire harness's running along side the trans to..so i dont have as much room as you probably do. I wouldnt pull up the carpet..id an X where my panel would be and just fold it back while im taking the bolt out. Taking the console out is 2-4 bolts that are EASY to get to...no big deal.
Location: Your girl's back door giving her the long stroke while you're at work
The bolt pissed me off to start with, so i decided to drill the hole. It wasn't right the first couple times so I made sure I made enough room the last time. Like I said I cleaned it up before I put the trans back in.
The only I drilled the hole is because I've got solid mounts and I almost rounded off the head of it trying to get it out.
