4L80E Shift kit & manual valve body ?
Old 09-30-2008, 10:18 PM
Randy WS6's Avatar
Default 4L80E Shift kit & manual valve body ?
Im in the process of rebuilding a 04-4l80e to put in my 2000 M6 TransAm and wondering do i need to buy a shift kit with the manual valve body kit, Im looking at the Transgo stage-3 with the vacuum modulator, and if i need a shift kit witch would be the best and hardest shift, I will be using a 4400 stall also
Old 09-30-2008, 10:40 PM
LS1Tech Sponsor
performabuilt's Avatar
The HD3 is a shift kit you have all you need shifts can be set by spacers and hole size but bear in mind the "hardest shift" is not allways the best thing
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 10-01-2008, 12:43 PM
Randy WS6's Avatar
I under stand, i guess i meant were ill be using nitrous , I need a quick shift ,don't want to lag between shifts and cause the trans to slip.
Old 10-01-2008, 01:06 PM
LS1Tech Sponsor
We as I said the HD3 is a shift kit and it gives you options for various shift firmness settings so should be all you need
__________________
Call 888-744-6542
Old 10-01-2008, 01:48 PM
Firechikn's Avatar
Do you know off the top of your head, which one of the hole in the separator plate is for whick gear? The 3 you have to drill I mean.
Old 10-01-2008, 09:13 PM
Randy WS6's Avatar
I am planning to rebuild the tranny this weekend and woundering is there any enturnal modifacation that will be needed with the manual valve body, What im tring to say i dont have the manual vale body kit yet but was going to stack the tranny . Do i need to wait till i get the MVB kit first ?
Old 10-01-2008, 11:40 PM
jakeshoe's Avatar
I would recommend you wait.
The kit includes some heavier direct clutch piston return springs and a heavier snap ring for the intermediates.
You could skip the heavy direct springs by drilling a .050-.060" bleed hole in the outer edge of the drum behind the piston so it doesn't centrifugally apply, however the intermediate snap ring should be installed in any performance application of a TH400 or 4L80E.
You will also have to drill a hole if you use the vacuum modulation system, no reason to risk getting shavings in the trans.
There are some pump mods too, full time lube mod, etc.
Are you rollerizing the rear planet to case? Another good easy mod to do while there.
34 element sprag?
If you have access to a lathe you can add a torrington to the forward hub easily too.
Old 10-02-2008, 06:54 AM
Firechikn's Avatar
Like he said, you should wait till you get the kit. Just remember to set the clutches up on the tight side. I'm no trans. builder by any means, so I set the clutches up to spec. All is well except the 2-3 shift is slow. Too much clearance from what I've read. I'll probably pull it, and restack in a couple of months.
Old 10-02-2008, 08:28 AM
Randy WS6's Avatar
My kit is a Alto Red Eagle Power Pack clutches and Kolene Steels ,with seven clutches and six steels ,for the direct and forward drums and five for the intermediate , And the Raybestos Blue plate special four over drives and three over runs. And all new sprags ,34 element , and new bushings ,trust washers and shim kit ,thrust bearings , all new injected molded pistons.Carbon fiber rear band, Carbon fiber 1-1/4 front band , My tranny is a 2004 4L80e ,witch has all the new updates.
jakeshoe, posted some mods for me to do, I can do them i have the resorses and tools but need a little more brakedown on them like :
1.There are some pump mods too, full time lube mod, etc.
2.Are you rollerizing the rear planet to case? Another good easy mod to do while there
3. you have access to a lathe you can add a torrington to the forward hub easily too.
4. drilling a .050-.060" bleed hole in the outer edge of the drum behind the piston so it doesn't centrifugally apply
can some one help me on this by posting or pm me the specs
Old 11-27-2008, 08:49 PM
Randy WS6's Avatar
Im going to order the MVB kit tomorrow,Who has the Transgo -3 kit ? My trans is a 04 4L80E
Old 11-27-2008, 08:56 PM
Randy WS6's Avatar
Does the kit come with a new separator plate ?
Old 11-28-2008, 07:15 AM
forcd ind's Avatar
i have the man kit and a 2005 unit im going to rebuild-i think you reuse your sep plate, and some work is done to it, blocking holes, etc-i have read the directions a couple times, a lot of work-not sure what the vac mod is for, maybe soften up the shifts under vacume?-i think it goes where the force motor was, but the directions are sometimes vauge, kind of have to fig it out
they give you some options for shift hardness, prob better to ck with someone who has done it to pick the right hole size
as i start on my trans rebuild, there are a couple tools needed, i'll have to round up someone that has them
Old 11-28-2008, 10:25 AM
Randy WS6's Avatar
The vacuum modulator is for the line pressure ,It replaces the force motor were the ECM would control the line pressure.
Were did you get your kit from ? I've been seaching around and every body ive talked to say theres dont come with the modulator.
And what do the kits cost?
Thanks,Randy
Old 11-28-2008, 02:53 PM
forcd ind's Avatar
i called Summit and they had it drop shipped from Transgo, around $230
i guess the 4l80e is a little diff than doing a 400, when i did the manuel v/b on them, we did away with the mod.
Old 11-29-2008, 05:21 PM
Randy WS6's Avatar
The 4l80e have a electronic valve body, So when removing the ECM out of the loop, there is nothing to control the line pressure, So i will need to in stall a modulator to replace the force motor.
Old 11-29-2008, 05:47 PM
Firechikn's Avatar
My kit came with the modulator kit.
Old 11-29-2008, 06:46 PM
Randy WS6's Avatar
Were did you get it ?
Old 11-30-2008, 07:05 AM
forcd ind's Avatar
my kit from Summit had the mod kit-it is sep from the main instrs., has its own-it looks like the mod valve is actually going to be inside the trans, they give you a fitting to run thru the case-sure hope the little hose they give you is for trans fluid, lol
years ago i used heater hose for a p/s return line, dam thing melted from the fluid-thats when i learned its gotta be special hose, lol
when i was looking for a transgo dist, one near me had a kit, but had it a long time, never sold one, so i kind of fig. with Summit having it drop shipped from Transgo, i would get the latest
i know the HD2 shift kit has been upgraded with a sep plate and vid, as i have an older kit laying around, so they do some upgrades on their stuff
Quick Reply: 4L80E Shift kit & manual valve body ?
