Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Under Hood Light
Old 04-09-2011, 08:59 PM
Stone17's Avatar
Default Under Hood Light
Got the hood light from Dodge Dealer.
Mopar Performance P56021441 Cost $23.
But I could not keep the light stock. So I added 1 watts led (2x) and a switch.
Here is it installed.
This was the only light on outside.
Old 04-10-2011, 08:23 AM
CTS-V Shifter Sales
07CTS-V's Avatar
Looks good, I've been thinking about installing a light under my hood also.
Do the vice grips come standard with your hood strut?
Old 04-10-2011, 11:28 AM
Stone17's Avatar
The vice grips are aftermarket mod.
Old 04-10-2011, 11:33 AM
Stone17's Avatar
The gravity switch on the light still works fine. The switch was just to kill power if you did not want it on.
I ran the power wire with a fuse to the battery and the negative wire to a bolt on the chassis.
Old 04-10-2011, 04:22 PM
JNR_Design's Avatar
Cool and definitely can be helpful! I cannot believe how cheap the manufacturer's have gotten to where they don't even put in a simple underhood light.
I forgot if it was only aftermarket or an oem unit, but I remember seeing one that was normally docked like that, but you could disconnect it and pull it down and around, etc. Must've had a tension spool (like a seatbelt) though, or else hanging wires wouldn't be fun
Edit - yeah, looks like they were used on 88-98 GMC trucks, for one: http://cgi.ebay.com/ebaymotors/Retra...-/160570337422, so time for junkyard search!
Old 04-10-2011, 09:02 PM
Stone17's Avatar
My friends 92 GM truck has that light on the side.
This is the first car that never had a hood light
I got the ideal from the LX Forums.
Yes even Dodge is cheap.
http://www.lxforums.com/board/showthread.php?t=42858
Old 04-11-2011, 07:16 AM
BudRacing's Avatar
It must be from the assumption that the general public are morons and only the dealer will be servicing the car... and never at night in the driveway or on the side of the road...
Old 04-11-2011, 11:00 AM
DrSpeed's Avatar
Right on!
You gonna make a few to sell?
Old 04-11-2011, 12:43 PM
Stone17's Avatar
Originally Posted by DrSpeed
Right on!
I could but the Cost in parts is $41.
LED $14(x2)
Switch $2
Hood Light $25
Hit me up if you want one.
Old 04-11-2011, 01:07 PM
JOHN STEPHENS's Avatar
I like how you cut the engine cover. did you just cut it with a jigsaw? and how much time did it take you?
Old 04-11-2011, 01:36 PM
Stone17's Avatar
Read this.
I used a jigsaw. Took about 5 mins to cut.
https://ls1tech.com/forums/cadillac-...tor-cover.html
Old 04-11-2011, 04:00 PM
DrSpeed's Avatar
RIght on....PM'ed ya.
Old 04-13-2011, 11:31 PM
A-Bomb's Avatar
Looks good, man! I haven't heard from u in a while.
Quick Reply: Under Hood Light
