Which Transmission Mount is better UUC or CS
Which transmission mount is better and why? I plan on changing mine b/c of the 1st and R
"sometimes hard to get in gear" problem even after changing all shifter bushings.
I'm leaning toward CS b/c they have great customer service, products I have bought are great and they give military discount
thanks in advance!!
thanks in advance!!
I installed the CS without unbolting the exhaust, but it did require some maneuvering of the crossmember. I have seen/heard of the UUC trans mounts bolts coming un-done from within the mount.
If you still have stock exhausts on, you'll probably want to have something hold those in place as that might be too much weight to flex.
I installed it without unbolting my exhaust. I have stock minus the mufflers. The old one came out easy but the new one took some tricky maneuvering. Overall CS is the best company I've dealt with in a long time.
My exhaust is factory minus mufflers too, but I really don't know if I'm comfortable undoing the hangars and just letting all that hang... Eeek!!
I have no hesitations with CS either. Dealt with Max for my motor mounts and it was superb.
Don't worry about it! I let mine hang the whole time I was changing the front diff bushing & while I was doing the trans mount (separate occasions).
Here's a pic of UUC's trans mount next to OEM. The first turd UUC mount I bought off them, the bolts turned in the polyurethane. Luke sent me a new one and I haven't had trouble with it...yet.
After that and having to replace their engine mounts for the 2nd time I say **** UUC. Go with CS.
