Hotchkis Sways - Anything I Should Be Aware Of?
Hey,
I just celebrated my first grad school semester by purchasing the Hotchkis sway bar kit on Amazon. Read the manual--everything looks straightforward.
Did any of you have any problems installing the kit, and if so, what kind of hoops did you have to jump through? Did you have any alignment problems afterward, or wind up going back to one of your stock bars because you didn't like the way your car handled?
I was on my cell couldn't see your signature...ya, have good set of drill bits and don't go to large when fitting the links..if I recall one member went slightly to and got noise because of it.
Wasn't hard at all to drill, just verify your bit with the stud on the new endlinks..I can't remember if I ended up using the 15/32 bit or something one step smaller.
just fyi, install the endlinks before you tighten down the bar on the frame, otherwise you won't be able to line up the holes.
