Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Is there a 60,000 mile service for our V's?
Old 11-18-2013, 11:12 PM
thefullmonty_07's Avatar
Default Is there a 60,000 mile service for our V's?
Just curious, I had the wife's Cayman done recently and was just seeing if one existed for our cars and if so what consist of it.
Old 11-18-2013, 11:46 PM
MN_V's Avatar
Check your belts. If they look okay without cracks you're probably good until the 100k spark plug and coolant interval change. Actually I think the Dexcool is now 150k or 5 years but 100k sounds like a good time to change it out.
Old 11-19-2013, 12:06 AM
That was my main concern was the belts, already did the spark plugs and rear diff fluid and oil every 3000k but just wanted to see if I should take it in...i'm about at 75000 right now. Thanks for the help!
Old 11-19-2013, 01:24 AM
bmylez's Avatar
You do oil every 3,000,000 miles? (3000k). Sorry, had to. But seriously, 3000 mile oil change is a waste of money, even if it's conventional oil. If you're doing 3k miles with synthetic, you're really dumping money down the drain.
Old 11-19-2013, 06:36 AM
Stone17's Avatar
Get the Goodyear Gatorback Belt.
GOODYEAR Part # 4040388 Gatorback; Effective Length 39" / Outside Length 39.75" Air Conditioning; Poly-V $12.91 at Rockauto
GOODYEAR Part # 4060815 Gatorback; Poly-V; Effective Length 81.75" / Outside Length 82.5" Accessory Drive; Poly-V $20.79 at Rockauto
Rockauto discount code A4264E97BE89
Old 11-19-2013, 06:30 PM
BudRacing's Avatar
You forgot to mention changing diff fluid every 3k too. Now THAT is just silly and wasteful.
Old 11-19-2013, 07:07 PM
Well its just the way I've been doing it with the car and doesn't bother me at all. I try to keep it around 3000...I don't sweat it if I go over and I'm aware it's good for way more that but I keep it in that range. I only do that with the oil, I've only changed the Diff fluid once as well as the spark plugs.
Old 11-19-2013, 07:10 PM
BudRacing's Avatar
Ah, looks like I misread.
Old 11-19-2013, 07:15 PM
Might of wrote that the wrong way, mybad
Quick Reply: Is there a 60,000 mile service for our V's?
