Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Opinions on my modifications
Old 03-11-2014, 11:57 AM
steves ls6's Avatar
Default Opinions on my modifications
I want to make sure I have all my ducks in a row to hopefully minimize or get rid of most of the wheel hop. I am going to replace the motor, trans, and diff mounts. Cradle bushings and axels. Am I missing anything else? I am going to use creative steel for the mounts and bushings and Gforce for the axels. My car is 99.99% stock but I am planning on increasing HP in the future.
Old 03-11-2014, 12:11 PM
Onefast V's Avatar
clutch/flywheel (LS7, LS9, etc. depending on power plans). more to get rid of the parade clunk but still a must do in my book.
Old 03-11-2014, 12:52 PM
bmylez's Avatar
You are definitely on the right path firming up the drivetrain before adding power. I did gforce axle and diff mount right when I got the car. Happy modding.
Old 03-11-2014, 01:10 PM
punishmentcycle's Avatar
deff put a clutch on your list before adding power..
Old 03-11-2014, 06:34 PM
Dmax/04V's Avatar
An 8.8 from Creative steel is a great investment. I would be wary of putting poly bushings in the control arms if the car is a DD as they squeak, for track use they are great. A good shifter makes a world of difference as well, and I will second the clutch. I had great luck with the katech ls9x clutch on my 04, took a lot of abuse at autox events and with regular driving (I was at just above stock power levels). Upgraded sways are a good investment.
Old 03-11-2014, 11:50 PM
54inches's Avatar
RevShift for ALL of your bushing needs.......
Old 03-11-2014, 11:56 PM
bmylez's Avatar
Just an opinion . Nothing wrong with CS.
Old 03-12-2014, 09:45 AM
barrok69's Avatar
CS bushings are greasable, which is a nice advantage.
Old 03-12-2014, 11:29 AM
54inches's Avatar
Very true on both accounts....just giving him options.
Old 03-12-2014, 01:29 PM
ryridesmotox's Avatar
Any bushings can be greased... All you need is a zerk, the proper drill size, and a tap.
Old 03-14-2014, 04:22 PM
steves ls6's Avatar
Its not my DD so I am not too worried about squeaks. I am just hoping for no vibrations. I guess for now I will do the mods I mentioned and save the work on the clutch/increase in power for the future. At this point in time I just want the wheel hop to disappear so I don't have to worry about breaking anything.
Quick Reply: Opinions on my modifications
