V whp upgrade brainstorm
Mast small bore LS3 heads, black label choice
Ported/custom LS3 intake LS3 or LS2 throttle body
LS6-2/3 harness adapter for tb
Injectors, FIC
Custom grind cam
Custom Intake & 100mm maf from LPE or TSP (or if you can custom tune a ls3 maf in) if this option is needed…considering flow of current intake and 85mm maf may be a choke point.
My local shop (GPI) and I are playing with this idea. My goal is high 400whp range.
I just want a fun street car, no plan to drag race it.
Injectors, FIC
Custom grind cam
Injectors, FIC
Custom grind cam
Injectors, FIC
Custom grind cam
I think Lollygagger didn't even break 450 with a Tony Mamo ported AFR/FAST 102/Cam package.
346 max effort, heads and flow mods to compliment a huge cam with fly cut pistons and high compression (12:1) can net around 500 whp out of an ls6. But......there are more problems with reliability and such that arise.
we are discussing if that is too much head considering a custom cam may change some of it. We'll see. The dude posted the livernois combo at 441...this above combo has more potential for sure. I like the idea of the rect port heads because that lets me change cams next year and put a heartbeat maggie 2.3 on it. Plan b would be:
TFS215 heads (more velocity for stock cubes, should yield good solid midrange)
fast 102/102
Injectors, FIC
Custom grind cam
fast 102/102
Injectors, FIC
Custom grind cam
I KNOW what it takes to take a stock LS3 to 500whp and I can do that for $10k with labor and sell my 45k mile LS6 longblock to offset a chunk. (5th gen camaro experience there)
I can get a maggie112 kit for the car for dealer pricing plus labor. I can get a great deal on a custom d1sc kit as well. I just really want to try NA. Maybe this isn't the car. I dunno. Tvs2300 not avail for cathedral in this pulley offset from what I have seen.
You can put together a 2300 kit for cathedral ports if you want to make the effort. Procharger is more involved and still lacks the fun low end torque.
Nah...my camaro was 3850 making 654whp through a v3 vortech and running mid 10 s....a centri will work..gears shift in a tranny. I would like to try a roots blower, though, yes. But with the kit for the V getting cut...I am not too fancy on it. Maybe I will just be happy with 440-450 whp and stick with cathedral heads, NA...plus spray it for 550!
Assuming you pay labor and don't do it yourself. I don't have the equipment to do machining so that would add to cost for me. But that said, I'd probably do a SC build with a fresh lower end. I don't want to just slap a blower on a car with 100k miles. I'd do the install on the supercharger myself. Labor cost varies so much is hard to compare it in a books thread. But cost wise, cheaper to keep it NA
Oh, well slap some forced induction on that bastard then. The motor is just getting broke in. Maybe I missed it earlier but did something break? Is that why you are rebuilding so early? I mean, other than staying in a specific class for a NASA or SCCA group, I'd use a power adder over a stroker. 1 day of downtime vs a week of down time possibly. And I can do it in my garage.
