Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
T56 no reverse while engine running
Old 05-30-2014, 03:13 PM
JesseCTS-V's Avatar
Default T56 no reverse while engine running
Hey guys,
I just picked up an 07 CTS-V about a week and a half ago with 23k on it. It seems every day it has been harder and harder to get into reverse. Now reverse is pretty much nonexistent unless the car is turned off, then it goes right in no problem at all. I am not very familiar with the T56's at all, but what should I look at? Hydro clutch fluid level is fine. All the other gears shift nicely.
Thanks.
-Jesse
Old 05-30-2014, 04:41 PM
Becker's Avatar
I would confirm a good bleed and fluid and check your motor and trans mount sagging. Is it easier to go into another gear before reverse? If so I think it may be a reverse synchro issue internal to the transmission.
Old 05-30-2014, 04:47 PM
JesseCTS-V's Avatar
Going from 1-R, or any gear for that matter, doesn't help. It's just weird it only does it with the engine running or key turned to ACC. I wonder if the reverse lockout solenoid is stuck shut when it gets +12v?
Old 05-30-2014, 04:55 PM
Fweasel's Avatar
You'd know if it was a lockout solenoid issue, you wouldn't be able to swing past 5/6. Sounds more like a air in the hydraulics to me. Get a turkey baster, suck out all of the fluid in the master, refill, then bleed.
Old 05-31-2014, 12:28 AM
JesseCTS-V's Avatar
Tonight I sucked out all the nasty fluid, and bled the clutch(pumped it 50x with the cap off). It does seem better, but still only goes in 1 out of every 3 tries. Anything else I should check out?
Old 05-31-2014, 06:37 AM
bigassogre's Avatar
i have a reverse repair thred on here if u search my name.
Old 05-31-2014, 07:29 AM
GFallen's Avatar
I have a reverse thread too! Haha common issue. Revshift trans insert made my reverse issue totally go away. I also have an 07, I really didnt believe the trans insert would make a difference, but it goes into reverse everytime. Good luck.
Old 05-31-2014, 10:09 PM
tmonttt's Avatar
When you say " bled the clutch(pumped it 50x with the cap off)", did you never crack the bleeder that comes out of the bellhousing?
Old 06-02-2014, 02:07 AM
hellride's Avatar
4th then to reverse always. This should be in the manual but it's not. Mine can be a bitch too when cold.
Old 06-04-2014, 08:36 AM
GA95DCMSS's Avatar
OP, how many miles are on the trans? Mine was having the same symptoms that you speak of for about a year before I lost the reverse gear bearing and it ended up shredding the rev syncro with it.
Quick Reply: T56 no reverse while engine running
