Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Why unstable at high speeds?
Old 06-03-2014, 05:24 PM
actrite80's Avatar
Default Why unstable at high speeds?
So I put my new wheels and tires on team dynamics 255-40-18 front 295-35-18 rear and now the feels really loose above 120mph any thoughts
Old 06-03-2014, 05:37 PM
serik21's Avatar
Let the fist layer of tire wear out. All new tires are mushy and have more movement.
Old 06-03-2014, 10:05 PM
garrettg's Avatar
That is a wide tire for a 9" wheel, maybe try more rear positive toe to prevent wondering.
Old 06-04-2014, 11:48 PM
actrite80's Avatar
Thank you will break them in and get it aligned
Old 06-05-2014, 07:06 AM
Andringa's Avatar
Make sure to read up on the suggested alignment specs on cadillacfaq.com before you take it in. If you are having issues, you need to make sure they understand that before doing the alignment.
It could be "in spec" and still not be quite right.
Old 06-05-2014, 07:12 AM
ls1247's Avatar
It could be in spec and drive like a peterbuilt. Seek out a frame repair shop to find the most skilled driveability experts IMHO.
Old 06-05-2014, 10:27 AM
actrite80's Avatar
It drove completely fine and was really stable at 165 after new tires and wheels scary at 120
Old 06-05-2014, 11:07 AM
ls1247's Avatar
Putting wider wheels on the car will exaggerate the existing alignment specs just a little.
Old 06-05-2014, 05:14 PM
isis's Avatar
Plus the TD wheels are lower offset too which will make it feel more wander-y if it's off just a little
Old 06-05-2014, 06:55 PM
actrite80's Avatar
You would think with a wider stance it should be more stable
Quick Reply: Why unstable at high speeds?
