Washed my motor, now codes P1125 & P2121 Reduced engine power
1 Post
P2121 Throttle/Pedal Position Sensor/Switch D Circuit Range/Performance
P1125 - Throttle Position Sensor Intermittent
Pull throttle body off, clean with electric cleaner, put back, relearn throttle position.
Looks like you wet the throttle body sensor.
Here is what I found
http://www.cadillacforums.com/forums...sed-water.html
