05 V stock pump/injector limits?
1 Post
Stock pump itself isn't bad. The wiring isn't exactly great though. If you want to touch and upgrade that pump though, don't overlook the racetronix harness. One of the best things I've picked up after my walboro 255 upgrade.
I have not 1, not 2, but 3 spare CTS-V stock fuel pumps. If anyone needs one, just lmk.
spring change on this motor isnt that bad, well comparing to an f-body that hides two cylinders from you.
I agree with the others that you should upgrade heads if your pulling them.
CTS-V Shifter Sales
I wouldn't waste my time pulling the heads if it were only to make it easier to swap springs. I find it harder to swap them on the bench. Buy this tool and use an air compressor to hold the valves up.
http://m.summitracing.com/parts/tfs-90306
If you decide not to pull heads then this^ that tool is amazing. With air, I can swap all springs on an LS in the car in under an hour.
Good luck sir
Some people may be able to do it faster, but from what I've seen, the first couple times aren't going to be quick. Looks like Brian agrees with me anyway . But if OP is experienced with pulling heads and doesn't mind the extra labor, more power to him.
Also, I didn't think the CTS-V got special LS6 lifters. I know some LS6 valve train components were updated in '01 or '02, and that's what the V would have.
