New 1st gen owner questions
Hi, while trying to fix an inside trim panel i found a thick cable that was cut. Anybody know what it is for?
Also in trunk on passenger side there is a square indentation with 4 holes, no clue on what it is for.
Thanks in advance for any enlightenment.
There is nothing mounted to that indention. Maybe the origin owner had an amp or something there. Get a better pic of that wire. May be the antenna wire or power to the lights in the headliner.
Seems odd that an aftermarket wire would be routed through an empty OEM wire tie attachment. I would be worried that it was an original wire and now disconnected.
My passenger side trunk panel has the indent and four holes you're describing. That's from the factory, nothing installed there, nothing missing either.
The previous owner installed an amp in trunk but as far as i can tell it's still functioning. Maybe an old ground that he changed? To my knowledge everything on the car works as it should. Thanks for all your responses.
