Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Combo Ideas (mild/stealthy setup)
Old 09-02-2014, 02:31 PM
-Ross-'s Avatar
Default Combo Ideas (mild/stealthy setup)
What does everyone think? I want a street friendly / daily driver combo. Here's what I had in mind:
TEA LS6 Stage 1 heads (would re-use stock LS6 valves)
BTR Stage II N/A cam 227/234 .614"/.576" 113+2
or
Tick Stage 1 cam 229/232 | .61x”/.57x” | LSA113+3
BTR Trunion Kit
LS2 Chain
OBX Longtubes with high flow cats
Bone stock catback
LS7 clutch kit
G-Force Axles
Various bushing upgrades (rear differential, trans mount, motor mounts)
Oil pump upgrade?
Car will be a daily driver. Goal is more power with excellent street manners. Not interested in best 1/4 mile time, hard launches or squeezing every bit of hp out of the stock shortblock.
I just want a very noticeable increase in power...for merging onto the highway.
Old 09-02-2014, 03:18 PM
DMM
DMM's Avatar
BTR cannot be beat. Stand up guy and he knows his ****. I'd go with the BTR cam (not much diff between them) and get his SLR lifters also. I'd go with a stock GM LSA/LS4 pump. It's higher press/vol over stock at the price of a stock one.
Old 09-02-2014, 04:21 PM
93hatch's Avatar
https://www.texas-speed.com/p-1161-p...m-package.aspx
Old 09-02-2014, 09:40 PM
itsslow98's Avatar
Neither of those cams is stealthy lol but both will make good power. That setup will get you in the 420s-430s. IMO id probably not even do the heads if you're not looking to squeeze every bit of power out of it.
Old 09-02-2014, 11:09 PM
-Ross-'s Avatar
I should have elaborated. I just don't want it to be loud. I hate loud *** exhaust on a daily driver. Lopey idle is fine as long as street manners are good.
Old 09-02-2014, 11:11 PM
93hatch's Avatar
I cant find the link to the h/c package with trickflow heads, would love to go that route
FYI my car with long tubes and stock resonator sounded fine, I deleted it since my car is so low and it scraped everything. Replaced it with a regular x pipe and it made the stock mufflers sound so bad
Old 09-03-2014, 12:27 AM
Naf
Naf's Avatar
Get the LPE GT2-3 with their ported heads. Its nice and not so loppy, but gives you great power. You may also get their GT11 cam, its a little loopy but behaves very well.
Be prepared to pay out about 3,000-4,000 for everything.
I like your headers to stock exhaust, it will give you great tq at a sacrifice of a little hp.
Talk with Jeff, he will get you set up right...
Old 09-03-2014, 08:07 AM
ls1247's Avatar
The cam and heads seem to make sense but my concern with this package is introducing a droning exhaust system into my daily driver. You hear stories of it and I don't want to go there at all.
So with a tune, long tubes and new hi-flow cats working through an otherwise stock exhaust system, what kind of power increase can you expect and does it work well on a DD?
Old 09-03-2014, 09:14 AM
Bio248's Avatar
you could always create something similar to a corsa or borla exhaust that'd have a little better flow characteristic to it, but still be fairly mild until your into the happy pedal.
Old 09-03-2014, 09:40 AM
ls1247's Avatar
from all I've read, the stock exhaust really wouldn't be a huge liability with the setup the OP laid out. I'm just concerned about the added drone that the headers/cam might introduce like these guys are getting.....
https://ls1tech.com/forums/cadillac-...stion-b-b.html
Old 09-03-2014, 10:28 AM
Bio248's Avatar
so long as there is some form of a resonator and actual mufflers in the system, i don't see how it can drone that awfully. my catback is stock until the back quarter of it where the previous owner installed some bullet mufflers and magnaflow tips. it looks good and sounds better than stock, but it does drone a little. legitimate mufflers would probably get rid of all of that.
the problem with the B&B exhaust is that it's a 3" system. if you stick to the modest 2.5" systems you'll likely be able to keep the drone and overall volume down to a manageable level. i never understood why everyone wants to drive a car that's downright loud as hell all the time.
Old 09-03-2014, 10:42 AM
ls1247's Avatar
So are these numbers wheel horsepower?
Old 09-03-2014, 10:50 AM
-Ross-'s Avatar
From what I have seen over the years, there is not a lot of hp or torque picked up by swapping out a modern day catback. Some of them sound badass and I'd probably do the swap to go louder on a weekend cruiser, but I hate drone and do not want a loud vehicle for my daily driver. I would expect the longtubes and high-flow cats to add a little bit of sound, but my guess would be that the stock catback would keep the drone in check while not sacrificing much hp if any.
Well, I think I have put together a pretty good combo. I'd be happy with 400-415rwhp in this car.
Old 09-03-2014, 12:00 PM
HtownV04's Avatar
Maybe start with long-tubes, cam, and tune. Should be a nice increase.
Old 09-03-2014, 12:08 PM
Naf
Naf's Avatar
As a daily driver with stock exhaust and the upgrades i mentioned you are going to be 380-400 rear wheel realistic. If you go all out with gt11 and new injectors and ud pulley 420-430. But ur payin for it.
Dont expect to break the sound barrier on a few upgrades..
Stay with stock exhaust for no drone everything else has drone, dont be fooled
Old 09-03-2014, 12:33 PM
-Ross-'s Avatar
I considered that, but figured why not just have the heads done at the same time and only do the job (unbolting the accessories, headers, wiring, etc) and tune once. The cam swap will require new springs (those come with the heads anyway).
Old 09-03-2014, 10:00 PM
itsslow98's Avatar
You won't gain anything noticeable with the heads unless you do a FAST intake as well which means new injectors too. You will drop 2k on heads and gaskets for about 15-20rwhp.
Old 09-04-2014, 08:55 AM
bigti99a's Avatar
i would still pull the heads and do lifters and **** though. but i think personally i am just going to cam my V and skip aftermarket heads. maybe throw a n2o kit on it if i really feel the need for some HP.
Old 09-04-2014, 11:14 AM
-Ross-'s Avatar
The heads are $1338 from TEA and include ".650” dual springs and Titanium retainers" which I'd have to purchase anyway going with an aftermarket cam. So actually, I'm paying $1k for the ported heads and that would leave the option of going with a FAST, TB and bigger injectors down the road.
Maybe I'm overthinking it...or maybe I've got a good plan?
Old 09-04-2014, 11:22 AM
SIXLITR's Avatar
I don't think so but I'm doing a very similar setup through AI after breaking a valve spring. I could spend a little more to get the heads worked and assembled with the new springs and throw in a matched cam. I'll save the intake for later if I want to squeeze more out of it.
Quick Reply: Combo Ideas (mild/stealthy setup)
