Brake pads grinding on rotor
This **** is starting to **** me off. About 9 months ago, my front driver side caliper/rotor starting making a grinding/scraping noise. I removed the caliper and inspected it along with the pads and rotor. Nothing stood out as being obviously wrong. The grinding/scraping would pop up randomly, so it was very hard to diagnose. Some days, it would grind all day. Other days, not grind at all...
I upgraded to braided brake lines and I noticed that it fixed the problem.....temporarily. After a couple months, the grinding/scraping came back, but it would only last for a week, then go away for a couple weeks, then come back, etc.
I finally decided in November to try to rebuild the caliper. When I got it apart, it appeared that there was a small amount of pitting in one of the pistons and its cylinder. I decided not to chance it, so I bought a new caliper. Since then, it hasn't made a peep.
Fast forward to Sunday, when I did some adjustments to my coilovers...that was it. Go to work Monday morning and my front **passenger** caliper/rotor is grinding/scraping/screeching up a fuqqing storm. I wasn't super alarmed since I had already experienced it before, so I went about my way, but was very embarrassed when rolling through the parking lot, hah.
I got home and bled the caliper, and it didn't grind/scrape on the way to work this morning...but then it started lightly scraping on the way home. I pulled the pads and compressed the pistons all the way, then bled the caliper again...after pumping the brakes up and spinning the rotor, I can still hear the pad grinding against the rotor.
What in the bloody hell is going on???
If your driver caliper Pistons were pitted and dragging, it stands to reason your passenger caliper might be there as well. Your last round of troubleshooting doesn't tell you much, from my personal experience. When pads are compressed against a rotor while the car is in the air, they won't release completely and will always drag to some degree. You just don't have the wheel speed to knock the pads back into the caliper like you would while driving, especially on a fixed caliper where the pads don't have return springs.
It would be extremely bizarre to me if my passenger caliper suffered the same fate as my other caliper. What are the chances of a set of high quality Brembos having the same issue less than a year apart? I realize it's a logical conclusion, but the odds seem hard to believe.
Our calipers are getting a bit old. All the heat involved in braking can speed up the deterioration of metal. Could be that it suffered the same fate as the drivers side.
Yea the lines are garbage. I have steel braided line going in mine. Maybe you got a bad set. Or maybe the fluid wasn't changed for like YEARS before you got it or something. My brake fluid looked terrible when I flushed it out. Probably hasn't been done since they put brake fluid in it in 2004
I'm going to attempt a caliper rebuild since I already have the kit from before. If that doesn't work, I will begrudgingly cough up another $135...the annoying part is it doesn't affect the performance of the car at all...it just sounds fuqqing HORRIBLE and it's so embarrassing in traffic.
I am more curious about why calipers would do this. And why did it do it after adjusting my coilovers. It's just very bizarre and I would prefer for this not to keep happening. Doesn't break the bank but it's a pain in the dick and seems like it shouldn't be happening.
I went ahead and threw on a spare rotor that I didn't put on when solving the driver side last year. Took a video of it.
Apologies for shaking around, but it's difficult to film and get a good spin on the rotor. Look real close at where the rotor contacts the pad. There is a definite wobble to it. You can see the gap opening and closing as it spins. I also can hear a slight clicking from what I assume is the hub. Nothing really else there to click.
Trying not to just throw money at this problem. I guess I will rebuild the caliper this weekend and if that doesn't help...it's either get a new hub for $90 or a new caliper...bloody hell.
