Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Diagnosis HELP!
Old 04-25-2010, 11:19 AM
TheLAW's Avatar
Default Diagnosis HELP!
Fellas,
As many of you know, I am the new, proud owner of an 05 V. In the last week I have noticed the appearance of a weird grinding noise and I need help from the pros in diagnosing it.
Only happens occassionally...not a constant sound. Sounds like a wheel bearing going bad, but it isn't (we checked). It varies on the car speed...not the rpm of the motor. Driveshaft or something?!? We also put the car of a lift and tried to reproduce the sound and couldn't do so.
What is throwing me is that after owning the car for a week, this sound has now shown up and is occurring so sporadically that I can't track it down!
Thanks in advance,
LAW
LAW
Old 04-25-2010, 11:25 AM
itsslow98's Avatar
where is the sound coming from exactly?
GeauxCTS's Avatar
I had a similar problem. When I got my 04 V I heard a faint grinding coming from the back. It wasn't always there but I was occasionally. I turned out to be a bad bearing in the drive shaft (right before the rear diff). I had to replace the whole shaft because the bearing isn't a separate part. $1500 at the dealer. Ouch. I hope you have better luck.
Old 04-25-2010, 11:26 AM
TheLAW's Avatar
Not exactly sure. I would say around the center console or close thereby.
LAW
Old 04-25-2010, 11:28 AM
TheLAW's Avatar
This is what my mechanic is thinking and I am afraid of. Good news (I guess) is he can get the shaft for 800 bones instead of 1,500.
LAW
Old 04-25-2010, 11:44 AM
punishmentcycle's Avatar
pull the drive shaft out and check the bearing...if you feel is rough change it..if not..keep looking
Old 04-25-2010, 05:45 PM
STAGEUP's Avatar
Change the fluid in your differential.
Old 04-25-2010, 05:51 PM
CTS-V LEE's Avatar
maybe throw out bearing in clutch??
Old 04-25-2010, 06:03 PM
camarokid45's Avatar
X2 usually the seal will be leaking some trans fluid if it's bad though..
Old 04-25-2010, 09:23 PM
Yeqon's Avatar
Are you out of warranty already? I had a similar problem after getting stuck this winter. Luckily it was just my rear bearings.
Old 04-25-2010, 10:06 PM
TheLAW's Avatar
That wouldn't equal an intermitent problem would it?
LAW
Old 04-25-2010, 10:08 PM
TheLAW's Avatar
Considered this also...no difference when the clutch is in or out, so not the culprit.
LAW
Old 04-26-2010, 12:15 PM
TheLAW's Avatar
No more warranty : (
LAW
Old 04-26-2010, 01:43 PM
GhettoTy's Avatar
Like Stageup said, the dif is always a good place to start since it's a known weakness. And if it doesn't solve it, at least you have new fluid in there.
Old 04-26-2010, 03:29 PM
TheLAW's Avatar
True. Good call.
I will try that and post the results.
LAW
Old 04-26-2010, 09:06 PM
TheLAW's Avatar
Is there a bearing somewhere in in the "middle" of the driveshaft? My mechanic said there appears to be a joint or bearing before the rear end...he thinks that may be the issue.
LAW
Old 04-29-2010, 08:48 AM
TheLAW's Avatar
Changed the rear diff fluid. Problem not fixed.
Any other ideas/solutions?
LAW
Old 05-06-2010, 02:03 PM
TheLAW's Avatar
It appears that the problem squeal is still extremely unpredictable.....it will come and go as it wants. From what I can tell, no difference in driving style, speed, rpm, etc. makes any difference.
Any more input on this?
LAW
Old 05-06-2010, 05:04 PM
Stepside's Avatar
Well, noise or squeal. Two distinctively different sounds.
Since, you said that it does not make a difference with the clutch in or out, then I would be inspecting the pads & rotors for irregularities. At certain rotational speeds, the rotors/pads can generate a harmonic based on a particular irregularity. Also, how is your parking brake working? Does it release all the way. Good Luck.
Old 05-06-2010, 07:09 PM
raven154's Avatar
I'd say the carrier bearing in the middle of the driveshaft is taking a dump.
