Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Another Tire Question... but somewhat different.
Old 04-28-2010, 03:01 PM
Yeqon's Avatar
Default Another Tire Question... but somewhat different.
So I am thinking I am going to do the Vento's when I get my tax refund and quarter bonus at work. So I don't want to blow too much money on tires if I am going to go 19"s but the Dunlop M3's are wearing fast. There is a used set of Pirrelli's available for extremely cheap. They are the PZero Nero's with 7/32 left. Good rating on TireRack from what I can see but they are 245/40/18. I know the 40 is just the ratio of height to width. But will this cause any issue and history with these tires? Thanks all!
Old 04-28-2010, 03:22 PM
whisler151's Avatar
I run that size tire. You will have no issues with it.
If you are lowered, I prefer the look of the smaller tire. I think 245/45 fills up the wheel well too much on a lowered V.
Old 04-28-2010, 03:29 PM
SkullV's Avatar
Enter the sizes into the 1010 tires calculator. It says that it would make your speedometer nearly 4% off and they recommend staying withing 3%. It would also make the odometer mileage off.
http://www.1010tires.com/TireSizeCal...?action=submit
Old 04-28-2010, 04:22 PM
Yeqon's Avatar
Thanks that really helps. So in essence the car would think I was driving about 2.4 mph faster than I was actually going 60mph and really I would be adding a few more miles than I actually was driving. Which is really good to know. But if I only drove them until mid June early July It shouldn't be too bad. I guess my gas milage would improve unless I send the ECM back to Wait4me. Thanks for the help on the fitment and all. I wouldn't have even known where to find that. If anyone has any other ideas or reviews of the Pirelli's I will be checking back all day and I guess buying on Friday unless there are some negatives.
Old 04-28-2010, 04:29 PM
Stepside's Avatar
Bottom line: Go with the Hankooks Ventus V-12 and keep the overall diameter of each wheel/tire within 3% of 26.7 inches.
You did not specify the width of the wheels, as some guys run wide tires on narrow width wheels, which is not recommended. Always check tire/wheel Specifications. SPEC.
A wider wheel will pull the sidewall out with a wide tire to give you proper sidewall support and tread contact.
New = Safer in wet weather.
Old 04-28-2010, 04:59 PM
Yeqon's Avatar
I plan on running the Hankooks when I get the new rims sent out. For now these would just be running on my stockers. I just want to get off the winter tires for the next two months and these are dirt cheap!
Old 04-28-2010, 05:08 PM
Stepside's Avatar
Good Deal and you'll will also have a real spare tire.
Old 04-28-2010, 07:23 PM
SoJersey05V's Avatar
my 255/40/18 say difference is under 3%
also, anyone run the toyo t1r?
Old 04-28-2010, 10:19 PM
Yeqon's Avatar
Yeah the calculator throws out that brake failure warning. I am a little worried about that.
Quick Reply: Another Tire Question... but somewhat different.
