Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
HID Fog Lights?
Old 10-08-2011, 07:34 PM
greg_74's Avatar
Default HID Fog Lights?
Has anyone replaced their fog lights with HIDs? I like to run my fog lights at night but don't like how the headlights have the HIDs and give off the blueish tint while the fogs are the white/yellowish color? If so how much time and money was involved in the process? You guys think it would be worth it or should I just try to find some replacement bulbs that have a blue tint to them?
Old 10-08-2011, 07:54 PM
Stone17's Avatar
Its a easy install. All you need to do is drop the cover under the engine.
After that you will have access to the fog.
Here a picture of the rear of the fog light. Its just plug and play.
I went with 6000k HID cost $55
Old 10-09-2011, 03:05 PM
Skidmarcx's Avatar
Not a hard install at all... Just be sure to secure the ballasts
Old 11-13-2012, 11:30 AM
jamesdem1123's Avatar
Did you guys retrofit projectors in or just swap the bulb and put in ballasts?
Old 11-13-2012, 11:49 AM
Stone17's Avatar
Just installed the HID.
Old 11-13-2012, 11:52 AM
etcts-v's Avatar
I just swapped the bulbs and ballasts in mine, however Fuzzylogic and another guy have a running thread on the cadi forums for a retrofit of Projectors which looks sick. Been meaning to go that route just can't figure out how to smoke the lenses on the lexan yet.
Old 11-20-2012, 10:10 AM
RRsV's Avatar
Im getting sum 3K HIDs for my blinkers. WORD!
Old 11-20-2012, 05:58 PM
jeepster666's Avatar
Does the 6000k kit match the factory color well?
Old 11-21-2012, 08:35 AM
acaringnihilist's Avatar
6000k will be blue, something in the 4-5000k range would match better.
Old 11-21-2012, 10:08 PM
I did some googling and found that 4500k 55w and 6000k 35w would match stock pretty good. Any reason to not use 55w. I originally thought 35w due to it being a smaller housing, but would rather get more light output using the 55w if there is no concerns with it.
Separate note: Could I use some 35w HID for my DTRL in my Tahoe without any issues? Barley any smaller than the V fog housings.
Old 11-22-2012, 05:59 AM
Quik Z06's Avatar
Don't quote me on this, but I have heard of some people having issues melting parts when going with 55W compared to 35. I've always run 35w in every car I've owned (unless i came with factory HID's) and never had any issues. Im actually going to be doing some 35w 5K fogs on my V very soon, just been to busy to get around to it.
Old 11-22-2012, 06:40 AM
RADEoN's Avatar
55w is fine for me.
Old 11-22-2012, 06:38 PM
kl2onik's Avatar
stock i believe is 4800 so a 5 k would be ****. Unless you do both that is, IMO around 6K is the best color, above that it gets kind of ricey and draws attention from the cops. The car already gets enough attention from them...
Old 11-22-2012, 07:53 PM
MN_V's Avatar
55 watts drowns out the color and brings a 6k more so down to a 5k or 4500k color temp. I think you'd be fine with 55w in the V's fogs as they are not real small projector fogs like on some cars.
Old 12-16-2015, 10:22 AM
ls1247's Avatar
So 3 years later, how have these been holding up? Which kit seems to be the best? 30 bucks on ebay seems to good to be true...
Old 12-16-2015, 10:38 AM
MN_V's Avatar
Some 55w DDM ballasts and 5k ebay bulbs ($12 delivered) have been good for the last year, and prior to that I was running 3k DDM bulbs for 2 years - no problems daily driven here.
Old 12-16-2015, 11:06 AM
ls1247's Avatar
With the advancement of LEDs in the last 3 years, think these would be a worthy choice?
Edit...forgot the link...
http://www.ebay.com/itm/2x-9005-6000...5WUstS&vxp=mtr
Old 12-16-2015, 11:50 AM
BudRacing's Avatar
I don't think LEDs are quite there yet. Especially in a cost-effective solution. They're great for marker lights, but as far as casting light over a distance they aren't quite as effective.
Old 12-16-2015, 11:53 AM
Andringa's Avatar
I've had 4500K 35W DDM bulbs/ballasts in my Fog lights for 5+ years and they are still running great.
I've had 4500K 55W DDM bulbs/ballasts in my aftermarket dual halo headlights for ~2 years and they suck. One has drastically changed color, and both have issues where they fail to turn on.
LEDs are great for running/accent lights, but all of my reading online indicates that they can't produce anywhere near the amount of light that you get out of a 55W HID setup.
I've read a lot of people bashing on DDM lately, and I'm 50/50, considering the 35Ws are still working great, but the 55Ws are basically dead.
Old 12-19-2015, 04:37 PM
Choppy_Idle's Avatar
55W HID Kit 4,5k in my dual Halos and they suck and failed after half year, bulb died, got a new one with Ballast, but didnīt installed yet, light output was crappy with tinted glasses, think it was the Combo with these cheap lenses in dual Halos and the tinted glasses!
Back to origin D1S and what amazing difference to before...
Next step is put the best of both worlds together, D1S with the inner parts from dual Halos and cob DLR rings as bright as can be putted together in tinted origin housing, hope this will work?!
Then using the HID Kit in fog lights, but unsure if it will work without a lens into them, maybe try a STS fog light from the newer models, they have clear turn Signal and fog light with lens!
Best regards,
Ronald
Quick Reply: HID Fog Lights?
