Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
B&M shifter
Old 03-15-2012, 02:12 PM
  #61
CTSV_510's Avatar
I picked up those pvc pieces from Home Depot, $0.30 each. By your picture, the linkage is 3/4" wide, and the pvc pieces measure 3/4" plus the 1/8" end lip, so if 3/8" is cut off the length of each one, they should fit perfectly in there.
I got the brass pieces from Brian today for the center linkage arm, so as soon as my clutch kit shows up I will schedule an appointment and get all this put in. It should be done by the end of the month, I'll report the results here and some pics of the stock bushings that come out.
Old 03-23-2012, 02:15 PM
  #62
ls6junkie's Avatar
Cadzilla, you're the man! I'm going to be following what you did completely. Just out of curiosity, how much time is involved in dropping the transmission on this car? I assume it can be done in a couple hours tops. Is it a PITA to get back in? I've got plenty of experience, just wondering if there is anything about this car in particular that is going to bite me in the ***. It's my only car right now so I need this done in one day flat.
BTW, not really having to do with this thread, but do our transmissions take GM synchromesh? What fluid are you all using?
Old 03-30-2012, 10:23 AM
  #63
9t8z28's Avatar
How do I contact pisnuoff/brian/07-ctsv for the brass bushings?
Old 03-30-2012, 10:33 AM
  #64
CTSV_510's Avatar
I sent him a PM on cadillacforums. His name is PISNUOFF there.
I am dropping my car off at Fran's shop on Wednesday for the LS7 clutch install and they are going to replace these linkage bushings for me too.
Old 03-30-2012, 10:36 AM
  #65
OldCobraGuy's Avatar
You can contact Brian here. He's 07CTS-V I have pm'd him and he's been very responsive.
Old 03-30-2012, 11:22 AM
  #66
9t8z28's Avatar
Good choice goin with Race Proven Motorsports! What Slave are you going with?
Thanks for the contact info guys.
Old 03-30-2012, 02:57 PM
  #67
CTSV_510's Avatar
They've done a lot of work for me over the years, installed headers, tuned, re-tuned after installed the supercharger, retuned after 90 mm tb, now the clutch.
I went with the complete LS7 setup including slave.
Old 04-01-2012, 06:17 PM
  #68
NIKDSC5's Avatar
This is awesome. It is going to make me put my new clutch on the fast track, just to have the trans out to do this.
Now....mods, how about a sticky, with an organized list of everything needed and where to get it?
Or maybe someone can put together a package and sell it?
At any rate some seriously awesome information here! Keep it up Cadvilla.
Old 04-06-2012, 02:30 PM
  #69
CTSV_510's Avatar
Cadzilla you are a genius! Just got my car back with the bushings replaced and my shifter has never felt better! ALL slop is gone, I love it!
Everyone needs to do this yesterday!
Old 04-06-2012, 09:04 PM
  #70
Cadzilla's Avatar
Nice.. Did they do any of the jb welding or just replace the bushings etc? I also re-wrapped my shifter stalk with dynamat. Been driving mine for about a week..loving it so far. I can hardly discern the play in neutral while driving, I have to really feel for it..much better than before. In gear there's absolutely no play at all, very solid. I already take it for granted haha....
Old 04-06-2012, 09:47 PM
  #71
CTSV_510's Avatar
No jb weld, just the brass and PVC bushings and I can't imagine it being any tighter. I already have the b&m shifter and uuc bushings so that part was already done. It actually feels like I have a proper short shifter now.
Old 04-07-2012, 07:38 AM
  #72
KVS84's Avatar
Where do I find a B&M shifter? They don't list Cadillac on the website.
Old 04-07-2012, 07:52 AM
  #73
9t8z28's Avatar
The B&M shifter has been discontinued. You can sometimes find them for sale in the classifieds.
Old 04-07-2012, 07:53 AM
  #74
CTSV_510's Avatar
I believe it was discontinued. I got mine from atlanticspeed.com back in the day but it doesn't look like they have any left.
Old 04-07-2012, 08:31 AM
  #75
KVS84's Avatar
Damn! The B&M came with bushings that other shifters didn't correct? What are some recommendations for shifters? I need PVC from Home Depot, Brass bushings from CTSV07, Shifter from...?
Clutch is starting to crap out so I guess its a good time for the LS7 swap also!
Old 04-07-2012, 10:04 AM
  #76
When you call Brian for the bushings, have him sell you a shifter stalk as well.
Old 04-19-2012, 08:33 AM
  #77
hyprZ28's Avatar
Thumbs up Totally works!!
Originally Posted by Cadzilla
I agree with DMM.
B&M is the sheeit! gotta be your bushings or somethings loose. Make sure everything is torqued down everywhere. Dont listen to the people who say to leave the linkage bolt at the bottom loose. That's only if you have the crappy stock bushings, They are weak and will bind if torqued too much, limiting movement.. The B&M fixed that with metal bushings, so tighten away. Mine is TIGHT. no issues. Same goes for the 2 bolts that hold the shifter base down to the plate (tighten the nuts from under the car), and the 2 that are just under the foam in the middle of the plate. torque those to the max. If that doesn't do it, you may have other issues, or, sometimes you just have to double clutch it and reset the synchros. I've found that a drop into 4th resets everything nicely before entry into 1st or R.
Im new to the V family and after reading this then putting the car in 4th before reverse helped soo much! I was wondering why it was so hard to put the car in reverse (lol)
I also plan on replacing the trans mount, differential bushing/mount. Should help out even more!
Gotta love these forums!!
Old 04-24-2012, 10:22 PM
  #78
yooperLS6's Avatar
Default Sticky material
Nice work, definately sticky material and a must do at clutch time.
Old 09-18-2012, 04:59 PM
  #79
Onefast V's Avatar
all the pictures are gone!!! this was such good information!!! CADZILLA please rehost these images, this information is priceless to making the shifter feel much better.
Old 09-19-2012, 03:40 AM
  #80
Cadzilla's Avatar
I don't know what the hell happened. They are all still hosted on the photobucket page..
Quick Reply: B&M shifter
