Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Rounded Oil Drain Plug?
Old 09-03-2012, 04:12 PM
FuzzyLog1c's Avatar
Default Rounded Oil Drain Plug?
Hey, I managed to slowly round off the oil drain plug on my CTS-V. I've got a new, stainless steel one in the mail, but in the meantime, I'm trying to brainstorm how to get the old one off. Best guess at the moment is trying to file down the edges to exactly 14mm and pray that I can get it close enough to get a secure wrench on it.
Thoughts?
Old 09-03-2012, 04:23 PM
vmapper's Avatar
rounded the oil bolt? tisk tisk..
Vice Grip pliers.. muscle the pliers on...done
Old 09-03-2012, 04:40 PM
jmargo's Avatar
Have a welder ? Tack a nut to it through the middle.
Old 09-03-2012, 04:41 PM
FuzzyLog1c's Avatar
That's probably what's going to have to happen. *sigh* I have this thing about over-torquing bolts. Really gotta stop doing that. I actually managed to shear off 4 of my 24 lug bolts and had to replace them all this summer. Even broke the shells off the stock lug nuts. Sears probably wonders how I keep snapping 3/8" drive hardware. Most of my stuff is now 1/2" drive as a result, but there are a few things that are better handled with 3/8" tools.
Btw, Dactari sheared one or two pieces of 1/2" drive hardware getting his LS2 pulley off. Now that takes some serious strength!
Old 09-03-2012, 04:48 PM
jrob56's Avatar
Holy **** dude, use the right size drive and all I can say is torque wrench all your **** from now on if you are hulking everything..
Old 09-03-2012, 05:22 PM
54inches's Avatar
Round wrench:
Old 09-03-2012, 05:44 PM
dangrus's Avatar
Try a pipe wrench.
Old 09-03-2012, 06:07 PM
punishmentcycle's Avatar
So let me get this strait.. U can work on a car but can't figure out how to a stripped bolt out?!? Smh
Old 09-03-2012, 07:33 PM
Dmax/04V's Avatar
Drill it and get a marine counter (counterclockwise) tap in the center of the bolt. Then get a marine counter bolt and crank left on it. Good Luck sir.
Old 09-03-2012, 08:21 PM
soulja's Avatar
I had the same issue on my wife's pacifica. This is what I used. They work perfectly!
Amazon Amazon
Old 09-03-2012, 10:14 PM
FuzzyLog1c's Avatar
Of course I can. This particular one is really, really stuck. I've been eyeing a set of vice grips for a long time now, and I think I just found the excuse to buy one.
You know, in retrospect, I think I've bought nearly $1000 worth of hand tools to work on this car. Damn. I feel like a mechanical engineer version of Neo in the Matrix when he says, "Guns. Lots of guns" except I fantasize about moving up from my Milwaukee M18 to a V28 and buying a complete set of every short and deep socket on the planet.
Old 09-03-2012, 11:59 PM
Just use the vice grips and ur done
Old 09-04-2012, 05:40 AM
RADEoN's Avatar
Yep. Vice grips. The metal will crush, and you're free to turn. No need to make it harder than it needs to be.
Old 09-04-2012, 07:01 AM
DDTECH's Avatar
Is there still a head on there? Both snap-on and matco make a bolt removal kit for either drilling out or going on a rounded head to give it some "bite".
Old 09-04-2012, 07:04 AM
AAIIIC's Avatar
Originally Posted by 54inches
Could you please post a larger version of that? I can't quite make out the crystal grain structure of the metal.
Old 09-04-2012, 07:05 AM
RADEoN's Avatar
hahahahahahahahahahahaha
3,648px × 2,736px
Old 09-04-2012, 08:31 AM
Vemon's Avatar
why so much torque on everything? Thats not the way joints are designed. Every bolt is not TTY.
Old 09-04-2012, 08:53 AM
Stone17's Avatar
Get this
http://www.searsoutlet.com/10-pc-Dam...9&mode=buyUsed
Old 09-04-2012, 04:46 PM
54inches's Avatar
I certainly can; I have SEM photo of the grain structure.
Old 09-05-2012, 05:09 PM
DrSpeed's Avatar
http://www.qwikvalve.com/fumoto-f107n-valve.html
No more rounding. Use 1 finger to open drain valve.
Have it on my Superduty, Subaru, Lexus, and obviously the V. Never a drop spilled. I run a hose straight into a used oil container. Best part, you can change the oil hot without burning yourself.
Uh...there are petroleum based products sitting behind the nut.....
Quick Reply: Rounded Oil Drain Plug?
