Weird 05 CTS-V battery issue???
Just bought the car, randomly on the Nav Screen it will post up a check battery alert. The battery appears to be charging and its never had trouble starting.
You all have any ideas?
Thanks.
Thanks.
What does your voltage look like, and have you bothered to open the hood and see if the posts are clean and not all funky/gunky for a clean connection?
Yep, did all that stuff. Voltage is always over 13.3 volts, light never dim. Could be a ground but I am not seeing any bad grounds.
I thought maybe it was a glitch like the oil temperature gauge fault.
Thanks, I will take it to my shop this weekend and check all the grounds. Is there a particular area I should focus on, I know I was reading up and there seems to be a few areas that cause electrical problems on the V1 .
I got a replacement here:
http://fastlanepartssupply.com/shop/...mp-alternator/
I had to go for the higher output for my application.
