Ed Mod thread
"Ed Mod" was a term I coined back when we were fighting with H&R springs that dropped us 2-3x more than advertised. "EdmundGTP" (?) came up with a solution that I've been running for a few years now and has stood the test of time to this point. Basically just a hard-durometer "donut" cut out to shim the top and/or bottom of the spring inside its perch. I'm running a ~3/8" on the top AND bottom of my rear springs and it rides at a perfect height now. No tire rub, etc. OP - search threads that I've posted in/started. Most titles have "H&R" and "lowering" in the titles. You'll find all the info there. What exactly were you looking for?
Pretty sure he's referring to the suspension mod where take a 3/8 sheet of rubber and cut a disk that will fit just inside of the rear spring perches in order to raise the rear of the car slightly because the H&R's tend to sag or sit too low for peoples liking.
Here ya go...
EdmundGTP's H&R Spacer Mod
Here ya go...
Anyway... do the mod if you're not happy with ride height man. There are literally zero adverse effects from it. You might have to do a little trial and error with what size spacer makes you happiest, but that's really not a big deal. I'm actually going to be adding a 1/8" spacer to the FRONT as well... sometime, anyway.
That's why I got into this too. 19x10's with 275's out back. H&R's lowered more than 2", so I was getting tire rub quite frequently. This is definitely an easy, cheap, and safe remedy. Seems to be standing the test of time too.
I've got approximately 3/8" spacers on the top AND bottom of the spring and I think the ride height is perfect. I can fit 1 finger between my fender lip and the top of my summer wheels/tires. Closer to 2 fingers with the OEM winter tires/wheels. With the stand-offs removed from my mightymouse shock spacers, the nivomats now kick in exactly when I want/need them to, rather than being completely inoperable with them being installed as originally instructed. With minimal/no weight in the trunk or back seat, the nivomats don't mess with my ride height at all. But when I've got a few humans in the back seat or 10 big bags of mulch in the trunk, the nivomats adjust for the extra load and the height gets pumped back up to a safe level. It took a lot of dickin' around, but I'm finally happy with the rear. Now I just want the front end raised a 1/4" or less. ........I'm a little OCD.
