clutch install thread
I'm doing my clutch tonight so hopefully I can make a good install how to cause there really is not one but figured I'd make one for all the questions and I'm doing diff and trans fulid
Trying to edit the pics to show bolt locations and my torque wrench fell and stopped working so had to get another and finish its easy but some bolts are hard to do and this is my 3rd v clutch so I'll try to narrow in on the hard parts for yall
I'm all for adding to the knowledge base, but just to be clear, there are PLENTY of write-ups on clutch (namely LS7) installs man. You just have to search. I have no less than 10 threads bookmarked for reference. Probably the most in-depth is the Monster install that's posted over at Caddy Forums, but there are many others with tips, tricks, and so on. There are also a few threads that attempt to compile all of these tips and tricks.
Oh, and the Ls7 "kit" can be had from Gripforce on eBay for that price all day. Comes with the LS7 slave for well under $600.
Again, thanks for adding your piece and I look forward to seeing it.
While it's possible, I'd recommend separating the trans from the bellhousing first just to make things easier. I had a hell of a time pulling the bellhousing...I don't even want to imagine having to do it with 150lbs hanging off the end.
On a side note, it wasn't that bad getting to all the bolts, or at least I was expecting it to be awful before starting.
Offer grip force 550 shipped and they might take it depending on the mood or call .. I've hit a snag with the pics and bid being I can't upload to photo bucket only 7 pics will work but they are the important ones so IMA keep trying then I'll post
