04 V - Keeps shredding belts
I recently replace my alternator and belt tensioner. Now my V keeps shredding belts. I checked all the pulleys, no debris in the grooves, no rough edges. I triple checked to make sure everything is tightened down. Only thing I could possibly see as the issue is a little bit of play in the power steering pulley. I can actually move it in and out on the shaft maybe 1-2mm (estimated). But I didn't think it would matter if the belt was installed and under tension.
Any ideas?
Any ideas?
Your belt routing is wrong. I bet your belt goes from p/s pump to idler then to alt doesn't it? Run the belt straight down from p/s to alt then up to idler and then down around the balancer.
Don't ask me how I know this.
That and check the alternator bolt that hides right underneath the belt. The clearance there is very small and if the bolt is backed off at all it will rub. Don't ask me how I know this.
mine has been tearing the back rib off the belt....need to check pulley alignment and for damage to pulleys and also routing according to Raven's pic.....
I know one thing..my tensioner is not positioned like Ravens...it's almost on the stop for full loose....(more vertical)
That's a good point. Mine has been off for months though without issue. My first belt shredded because (from what I think) a bad tensioner and/or improper routing. 3 belts later and I have it routed correctly. I have an extra belt and tools in the car with me, we'll see if it shreds again. I'm definitely going to budget to replace the crank pulley soon. I just don't feel good looking at that wobble. 81.5k on the car.
