Questions about builds
I am new to this, and still do not have my car shopping around for a decent 06-07 with low miles and no work or damage done so that I know exactly what is in it. I was wondering if this build here was still viable?
http://www.popularhotrodding.com/tec...77346268204652
also are there better parts i could use for around the same price range? after purchasing the car i will have around 6k for basic upgrades any advice would be helpful.
also is this better than the FAST 102?
http://www.carid.com/2004-cadillac-c...-14144807.html
Thanks, is there anything i could swap out or go bigger on to get around 500whp?
Also what do you mean by cubes? I am new to this, will be my first build and im trying to learn all i can before going into it
If you want 500whp all motor you're gonna have to drop some coin on a stroker. A 427 is the easiest but you could do it with a slightly smaller motor. If you are new to the cts-v I would say don't worry about power until you get the rest of the car sorted out. It has a lot of quirks from Cadillac that need to be fixed first.
oh ok, other than boreing and stroking is there much else i could do besides what is listed on the build? i was thinking about a bigger cam but i dont know much about compression ratios and dont wanna mess something up. was also looking into afr 243s but unsure of the difference.
If there is anywhere you know that i could go to research this info a little more i would greatly appreciate it
oh ok, didnt realize there would be anything wrong with all the good reviews on the cars. I am coming from a stock 2012 camero 2SS, will i notice to much of a difference? I am in need of a sedan now, and the V seems like the best bang for the buck
The V is an awesome car. But like said above, if you plan on making power and trying to put it down, you will need to focus on those first. Plan on a 8.8 conversion, clutch, and radiator. All things that will give you problems if driven hard even on stock power.
stock to stock they are basically the same in power and speed. If you like to do dig races and beat on the car, what they said is true above. If you drive it smoother and more like the car was designed for like a road track vehicle, the stock diff isn't a huge issue. That's all up to you. People drop a lot of coin on cams and heads and install/builds but N/A upgrades don't make sense to me as far as gains vs. $$$$ spent on this car.
Just my two cents
Instead of going the power route right away I've been putting my money in beefing up the car first. All new mounts CS motor mounts transmission mount rear diff bushing. BMR pinion support to keep the rear diff from hitting the body. LS7 clutch and supporting mods. I've done a muffler delete with X pipe so far and a Hurst short throw. I'm in my car for about two grand but I don't want to be like my father in law and spend a lot of money on horsepower and blow his rear end. Just my advice.
edit: $30,000 includes the price of the car, so probably about $13,000 after purchase but i dont want to spend all that, would like to have quite a bit left over
Instead of going the power route right away I've been putting my money in beefing up the cat first. All new mounts CS motor mounts transmission mount rear diff bushing. BMR pinion support to keep the rear diff from hitting the body. LS7 clutch and supporting mods. I've done a muffler delete with X pipe so far and a Hurst short throw. I'm in my car for about two grand but I don't want to be like my father in law and spend a lot of money on horsepower and blow his rear end. Just my advice.
Would there be more work required than what you have done? like i said im new to all of this. Most of what my car will be used for is a really strong daily driver that I will rarely ever race and use more for show, just want the power because i have always wanted a car to put down near 500whp
thanks for help, is there anywhere i can get a full listing of the parts i would need to replace in the drive train in order to effectivly put down 500whp without tearing it apart? i already priced my engine build at 5500-6500 depending on if i can do 90% of the work myself, if i get the car for a decent price should leave me about 5-6k i could spend on drive train
Trans mounts- Creative steel, revshift
Clutch- LS7 if your end goals are over 500whp, you'll need something more substantial.
Rear cradle bushings- creative steel and revshift.
Ford 9 - GeForce
Ford 8.8- creative steel
most guys go 8.8 its more of a drop in. I like their kit with everything except the diff and housing since I'll be getting my own.
After you get all that **** taken care of, then do power adders. If you want to save money after all those bushings and rear end and clutch parts, just have the heads machined and install a mild cam with a 150 shot of nitrous. Its a lot less than forced induction or a big motor build. Have it tuned right and it will run good for a long time. That would put you 500whp+ when you are on spray. That'd be a pretty badass street car.
A bit of advice... More than once in this thread you said that you're new to this. I wouldn't build a motor 90% if you are still just scratching the surface. Mounts, bushings, and bolting in a rear end is one thing. Taking a motor apart is a little daunting the first time. Source a good local machinist if you really want the lower end worked on. They usually have good rates, talk to local guys and see what they recommend for a good machine shop that will put the lower end together. I've built a few old LT motors, I always had someone assemble it. They balance everything perfect, line hone the mains, clean, deburr everything, gap the rings and bearings properly, it really is money well spent... If you find a good shop. Not trying to discourage you, just trying to help out. I blew up my first LT1 because I didn't clearance the main bearing properly. It therefore, spun a bearing dropped oil pressure and that really sucked. I was climbing a hill so I was flogging the old girl at the time too, 4wd, slinging mud into the stratosphere. Ruined a cam, and bearings too because of the oil pressure dropping to zero and I was wide open. I had to make it up or risk rolling the truck.
Motor mounts- UMI, they are the only ones I have seen on here that have zero failures. I've looked over LS1tech and a few other places.
Ford 9 - GeForce
Ford 9 - GeForce
Ford 9 - GeForce
Ford 9 - GeForce
