V2 Brake Rotor Options
What are you V2 V1 guys going for as far as Rotors?
1) Brembo Drilled
2) R1 Drilled and Slotted
3) What are the Grey ones I attached also I see them everywhere but I cannot find what they are.
Also I'm toooo Cheap for 2 piece. If you are running 2 Piece rotors, You are Balling IMO
1) Brembo Drilled
So far, so good. I still have the 2 piece Colemans on the rears for weight tho until I can convince Girodisc to make a 2 piece for the rears...
Brembo sells two piece V2 rotors for a reasonable price: http://weaponxmotorsports.myshopify....front-complete
You can also get the OEM co-cast 2 piece rotors for about $230 ea. on rockauto
I've been buying the Girodisc through Luke and have a full spare set of fronts and rears.
Considering that they have held up well, I would buy a set or two of just the rings and hardware. Would love to get them to make a set for the rear as well...
*EDIT* At last mention, Bob was going to sell just the Coleman rings and hardware as well:
"Front/Rear
$255 each Includes all hardware 12 bolts washers and jet nuts with "WC" slot pattern
$241 each Includes all hardware 12 bolts washers and jet nuts with "Straight" slot pattern"
As for dead civic's options, if you're toooo cheap for the 2 piece rotors, why are you wasting money on slotting and drilling? You can get the Centric Standard plain rotors for $43 each on rockauto.
<<<@!1!@>>>
I've got to get some bling
the 2 Piece for 520, I'm going to be watching this tho. I usually run brembo Blanks. But not this time around.
EDIT: I guess I'm not too cheap for 2 Piece then.
Thanks for the heads up.
Amazon.com: ACDelco 177-1146 GM Original Equipment Front Passenger Side Disc Brake Rotor: Automotive
I'm running the cheaper Centric V2 rotors. They work fine for what I'm doing right now and are only $80 a piece from rockauto. My next set will be the two piece AC-Delco service rotors. I'm currently running the AC-Delco service pads as well.
yeah just fronts. I might hit them Brembo slotted, it's that or the R1 that have slott and drill.
I love the stock slotted ones in post 13. Anyone where they can get slotted like that, any machine shop? I searched on line for it but I didn't find anything.
EDIT: found a company called Boomba that does custom work on rotors. I might get mine to look like the DBA slot/dimple combo.
rjoffe: I emailed them today. Id their ok with it I'll mail them mine and deff come back with the turn out and price.
