HARD left steering
HARD left steering
Was driving around and it became very hard to make left turns. It's as if I have no power steering assist on left turns. Right turns are fine like normal. I checked my power steering fluid level and it was fine. Any ideas? '06 CTS- V.
I do have LT's but there is a lot of clearence with the steering shaft. There are no leaks. A mechanic buddy of mine said that the filter in the PS pump is clogged. When you turn the wheels all the way to one side or another the PS lines jump. He says that since that filter is clogged it's causing those lines to move. Any thoughts?
Well, if anyone cares, I'm pretty sure it's the rack and pinion. If it was the pump it'd be hard steering either way and also the same for a bad filter. All I can think of at this point is the rack and pinion. I know we have power assisted steering on the V's. Are there any sensors or anything else that would cause hard steering in only one direction?
LS1247 that's the same thing I was thinking. Nothing else explains why I get hard steering one in direction. The pump and the filter would cause both sides. Other than that I don't see what else the issue could be.
Isis I did check under the car and nothing seemed to be leaking or anything else. At this point I'm thinking it's the rack. I don't get why it decided to 86 it but oh well I gotta fix it. If anyone else wants to chime in please feel free I'm open to all ideas. Thanks.
Quick question, does anyone else feel a click in their steering wheel? When I first got my V I noticed a click in the steering wheel when I would turn it. Ever since I lost my power steering when turning left I haven't felt that click anymore.
Here is the listing on eBay. http://www.ebay.com/itm/Detroit-Axle-Complete-Power-Steering-Rack-and-Pinion-Assembly-with-Sensor-Port-/160543926656?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACTS%7CSubmodel%3AV&hash=item256129e980&vxp=mtr#ht_1735wt_1181
The only difference I saw was that some racks have the sensor and some racks don't. As far as I can tell we need the racks that do have the sensor. Are there any other differences in these racks that anyone else knows about?
