Radiator recommendations ('06)
My radiator decided to let off a lil steam this weekend in 30deg weather. I found the crack immediately after dropping it off at the mechanic: the passenger side hose attachment has a crack near it.
Is that a high stress area from the engine flopping around in the bay?
Regardless, I'm looking for options. I've heard Alradco, but is that still recommended for stock, non-FI?
3 oem under warranty and one China special that lasted maybe a year. Have the Alradco in it now but the car has been down for some time so no reports on it. I'm sure I won't have any issues with it though. The Alradco is a really beefy well made product.
Who cares if the OEM part has a lifetime warranty if it requires replacement with any frequency. Spend the money for a quality one and done solution so you'll never worry a bout the radiator again.
I have an Alradco, but if my car was still stock-ish and I didn't track the car, I would be perfectly happy with a stock replacement. Maybe my experience is unusual, but my stock radiator was perfectly fine until I put in the Alradco. And I've used a cheap aftermarket radiator on my Subaru for years with no issues (track days, auto-x, and daily driving).
As DarkCharisma said, the Alradco makes maintenance on anything at the front of the engine a pain. The water neck coming off the water pump now protrudes through the plane of the fan shroud, that's how tight things are.
Too bad alradco doesn't make a thinner one. LS motors don't have a problem staying cool in my experience. Any of you guys run an alradco with an 8rib pulley setup?
I'm running 8 rib with the alradco and its a tight fit. My Volant airbox won't work anymore so I'll have to build a plate to move the MAF up and see if I can make something work. It's really tight around the air tube. There is a V in the classifieds with the same setup. I asked for some pics around the PS pulley and MAF area. Hopefully he can get some.
